Installing headlight buzzer but lost instructions . . . . .
Old Nov 24, 2011 | 07:37 AM
jmonintwo's Avatar
jmonintwo
1995 model.
I picked up one of those little headligh buzzers b/c I'm always leaving my lights on.
It has two wires....a red and black.
Black is ground I guess.
Anyone have a guess where the red would hook up?
Thanks doods
Old Nov 24, 2011 | 09:36 AM
Edgethis's Avatar
Edgethis
I would imagine maybe the dome light/door switch...not sure tho. Maybe you could just wire wire the headlight relay so it needs the ignition to turn the lights on, similar to the radio or subs with a remote lead.
Old Nov 24, 2011 | 12:42 PM
TX76F250's Avatar
TX76F250
The red side goes to a fuse that is turned "on" with the light switch.
The black side goes to a fuse that is turned "off" with the ignition.
That way when the ignition is off, you "ground" the black terminal and if the lights are on, the red wire is +V, and the buzzer goes off.
BainbridgeBrewer
Electrical Systems/Wiring
Aug 7, 2016 10:08 PM
jeronlines
Dec 28, 2010 08:36 PM
speedx
Jul 13, 2010 11:27 PM
docholiday72tx
Jun 3, 2005 12:32 AM
biederboat
1978 - 1996 Big Bronco
Feb 18, 2005 05:27 PM
