Ignition - cluster light issue
Old Jul 13, 2010 | 09:46 AM
speedx's Avatar
speedx
I just picked up a 78 F100 from my neibour 200 bucks, good deal I think. Runs mint he was the orignal owner. So anyways it has an aftermarket radio in it, works ok, but when I turn the key for the ignition the cluster lights come on and they do not work from the headlight ****. So I saw in a thread that a wire might be wired together. I found the connecter that has a blue/red stripe and a black wire with what looks like a fuse but it is incased in a black thing. These 2 wires blue/red and that black one are connected together. I totally disconnected the radio and also seperated the blue/red and that black one, then the cluster lights would not work at all, I cant seem to find where these 2 wires should go, do they just hang there and maybe my headlight switch is not working? I tried turning the **** back and forth but nothing happens, the inside cab light does work all the way to the left.
Thanks for your replys ...
Old Jul 13, 2010 | 11:48 AM
steponit's Avatar
steponit
Blue/red is for cluster /dash lighting
or in your case radio light
The round thing is noise suprressor on the Radio POWER WIRE
disconnect them.
Check your fuse fuse for a missing fuse
That blue coded fuse for dash lighting is hard to find. 15 amp, but is shorter than the others
Old Jul 13, 2010 | 12:07 PM
speedx's Avatar
speedx
Ya I just came in from changing the fuse and what do you know .. they work .. thanks ... so heres another question .. when i pull the headlight switch both flashers for the left and right stay solid on .. when switched up and down they do flash correcty though any thoughts
Old Jul 13, 2010 | 12:14 PM
c.l.nye's Avatar
c.l.nye
start looking for a bad ground,probbaly at the tail/turn lights or front turn/parking. check the ground tabs in he bulb socket it self.
Old Jul 13, 2010 | 01:19 PM
steponit's Avatar
steponit
Do you mean T/S indicator lights stay on ?
That would be another feedback power wire attached to the T/S wiring
Check the wiring at the drivers side rear for a mess.
Old Jul 13, 2010 | 01:35 PM
speedx's Avatar
speedx
ya the turn signal lights inside on the dash stay on when i pull the headlight **** ... but everything works i did see a brown wire just hanging there but i read that is for some other accessory
Old Jul 13, 2010 | 11:27 PM
speedx's Avatar
speedx
well it was the 2 front sockets .. those ground tabs were bad ..plus the connectors inside the socket were pretty bad also .. I cant belive they want 20 bucks each for these .. Im in Winnipeg, Canada ..
