Weird self-healing hydraulic clutch mechanism
I went down to Sears & bought a $5 pin punch, 1/8" diameter, feels like it will fit.
I wonder if I can do remove the pin as illustrated in the YouTube below. Method didn't use a proper punch & seems kind of rough on the original master cylinder, but might make removal of the system a lot easier.
Press out roll pin that retains the hydraulic line to the clutch master cylinder - YouTube
The reinstallation looks a lot easier (this is something I've never before seen). I imagine installing the line this way sets up more air in the hydraulic system. At least the below video illustrates the effort in inserting a roll pin.
http://www.youtube.com/watch?v=kDb6z_Zix48
Getting it in is easy, getting it out can be a bit rough. Much better if you use a flat punch (not tapered) of equivalent size.
As long as the roll pin is tight, it doesn't really matter - it's not a sealing surface, it just keeps the clutch line from backing out.
Once you've done this, it'll all make sense.
Word of advice, don't touch the gold screw on the new slave cylinder, people swear up and down it's a bleed screw. All it will do is let you down.
I just installed the reinforcement bracket on my truck. I had the dash, motor, brake/clutch pedal hanger and seat out out of the truck and it was still a pita. I would not use the template supplied with the kit to drill the hole. I used the template and one of the holes was way off. I would suggest to remove the clutch m/c nuts, then install repair brace, use it as a guide to drill the 2 additional holes at the same angle as the m/c. Then bolt the panel, remove m/c and finish drilling the 2 other holes on the side flange. It will be a pain if you have to work under the dash with the seat still in truck. Best of luck with your project!
john.clark
13
10-12-2015 03:14 PM
bigdaddyII
02-26-2005 06:15 AM
Tony G
07-15-2004 01:35 AM
