I'm stumped
Old Nov 23, 2011 | 05:42 PM
arkredneck's Avatar
arkredneck
I'm stumped
My truck won't start and im stumped
No blown fuses
Wait to start light works
Changed idm
Changed cps with a working one from a running truck
Batteries are good
Glow plugs work
took chip out
But the tach does not move even with changing idm and cps anyone got any ideas?
Old Nov 23, 2011 | 05:51 PM
redman84's Avatar
redman84
Did you multi-meter the fuses for continuity? I've had several "blow" but not obviously at all. HPOP res and fuel bowl full?
Old Nov 23, 2011 | 06:38 PM
arkredneck's Avatar
arkredneck
Hpop is full fuel bowl is full all fuses ohm out ipr is plugged in
The tach does not move when cranking wait to start light works and CPs is good
Old Nov 23, 2011 | 08:20 PM
DIYMechanic's Avatar
DIYMechanic
You checked the fuses under the hood too?
Old Nov 23, 2011 | 08:44 PM
oldbird1965's Avatar
oldbird1965
IPR could be stuck, happened to me. But, then again, that doesn't have any thing to do with the tach not moving? Is the CPS seated in all the way and the wires and plug OK?
Old Nov 23, 2011 | 08:45 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
I dont know what to add to help you. You dont have the 10K mod, right?
Wiggle the harnesses. is tight the IPR nut?.
Good luck.
arkredneck's Avatar
arkredneck
All fuses under hood are good I'm thinking a bad PCM when chip is plugged in it won't light up
Old Nov 23, 2011 | 09:07 PM
plgebbia's Avatar
plgebbia
You probably have an issue with the cps connector. the contacts can get loose. Take the connector off and see if the contacts are loose.
Old Nov 23, 2011 | 09:33 PM
Action4478's Avatar
Action4478
Umm, does it "light up " without the chip?...
Old Nov 24, 2011 | 06:59 AM
arkredneck's Avatar
arkredneck
The wait to start light always lights up
The chip does not light up when installed
I'll check the cps wiring today
Old Nov 24, 2011 | 07:37 PM
arkredneck's Avatar
arkredneck
An update the CEL lights up when cranking and from what I read PCM rarely fail
Old Nov 24, 2011 | 09:25 PM
DIYMechanic
I would have to check it for sure but doesn't the check engine light illuminate when you are cranking?
Old Nov 24, 2011 | 11:23 PM
1973dieselhighboy's Avatar
1973dieselhighboy
the cel will light when cranking if the pcm is not receiving a signal from the cps if i am right been a long time since i have had a crank no start without a crank signal. i would check all connectors and ohm between the cps connector and pcm also check for shorts or opens in the wires
Old Nov 25, 2011 | 12:09 PM
arkredneck's Avatar
arkredneck
Well I changed the PCM with a good one and still no start or tach movement
Anyone know where to get a PCM and CPS wiring diagram?
Old Nov 25, 2011 | 04:04 PM
arkredneck's Avatar
arkredneck
It started !!!! I really don't know what fixed it but after the PCM change the battery's was a little weak and it didn't crank good so I charged them and now it runs so glad I got a parts truck
