I'm stumped
Old Nov 27, 2011 | 07:03 PM
  #31
Action4478's Avatar
Action4478
Originally Posted by DIYMechanic
I would have to check it for sure but doesn't the check engine light illuminate when you are cranking?
The CEL will come on at key on for a light bulb check. If it is on while cranking there is a problem ..
Old Nov 27, 2011 | 07:27 PM
  #32
arkredneck's Avatar
arkredneck
I got 2 auto PCM and 1 5 spd
And swapping the questionable one into the running truck is a good idea I didn't think about it like that
Old Nov 27, 2011 | 07:52 PM
  #33
Tim Matthews's Avatar
Tim Matthews
Cam sensor maybe? mine went out and it woudnt hit a lick.
Old Nov 28, 2011 | 06:53 AM
  #34
DIYMechanic's Avatar
DIYMechanic
Have you tried unplugging the ICP and trying to start it?
Old Nov 28, 2011 | 11:13 AM
  #35
arkredneck's Avatar
arkredneck
I drove it today now it won't start again this is frustrating
Old Nov 28, 2011 | 11:19 AM
  #36
arkredneck's Avatar
arkredneck
Tried unplugging icp and it won't hit a lick
Old Nov 30, 2011 | 06:52 AM
  #37
coreylasalle's Avatar
coreylasalle
you said it was hit and miss, hows it run when it does run? do you have another scanner you can get hooked up to it?
Id say the tach not moving originally was the batteries being not charged up, or if there actually was/is a cps issue thats intermittent then maybe an issue in the harness? mine had a 3 wires that insulation was warn off in spots, but the exposed copper was green, so id bet its been that way a while. what other things on a psd can be intermittent?
Old Nov 30, 2011 | 10:08 AM
  #38
arkredneck's Avatar
arkredneck
It runs fine when it does start and the tach is moving when it won't I haven't dug into the harness yet but I guess I'm gonna have to I'm gonna try another gpr for grins. I think ipr can be a lil Tempermental
Old Nov 30, 2011 | 12:44 PM
  #39
fordpride's Avatar
fordpride
I would change the CPS and check the plug and wiring
Old Nov 30, 2011 | 03:49 PM
  #40
towsrus's Avatar
towsrus
i had the exact same problem. wires chaffed under the intake. if your not gettin any tach signal at all, you got a cps or wiring issue for sure, without 200 rpms on the scale it wont even fire the injectors
Old Nov 30, 2011 | 07:37 PM
  #41
arkredneck's Avatar
arkredneck
Tach moves Now even when it doesn't start
Old Nov 30, 2011 | 10:01 PM
  #42
coreylasalle
mine wore right under the intake too.
200 rpms required before the injectors fire? is that an exact number?
Old Dec 1, 2011 | 06:14 AM
  #43
arkredneck's Avatar
arkredneck
I've always heard 200 to 300
Old Dec 1, 2011 | 08:54 AM
  #44
Hussler's Avatar
Hussler
Some good information that might be helpful ...
Diesel Diagnostic and trouble shooting information for IDI 6.9 L and 7.3 L and Powerstroke 7.3 L and 6.0 L, brought to you by Oregon Fuel Injection
Old Dec 1, 2011 | 11:54 AM
  #45
arkredneck's Avatar
arkredneck
Thanks hussler
