I'm stumped
Old Nov 25, 2011 | 07:05 PM
DIYMechanic's Avatar
DIYMechanic
Hmmm, wonder what will happen if you swap the PCM's back. I always try to replicate the problem once I have figured out what I think the cause was. That way you're sure you got it. Glad to hear you got it started.
Old Nov 25, 2011 | 07:26 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Yes I have to agree with that.
Old Nov 25, 2011 | 07:28 PM
arkredneck's Avatar
arkredneck
Now it won't start again I dunno
Old Nov 25, 2011 | 07:42 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan
well nothing worse then fixing something and not knowing how then having it break again. sorry bud.
Old Nov 25, 2011 | 09:54 PM
oldbird1965's Avatar
oldbird1965
Great, congrats!
Old Nov 26, 2011 | 06:41 AM
DIYMechanic
Is that with the new PCM or the old one?
Old Nov 26, 2011 | 09:31 AM
coreylasalle's Avatar
coreylasalle
Any luck yet? I am having the, same problem. I have wts, good cps , no tach movement no start. Slightly aggravating.
Old Nov 27, 2011 | 05:16 PM
arkredneck's Avatar
arkredneck
No still no luck and I'm super aggravated I charged the battery's for a day so it would crank good
It cranks good still got wait to start the tach is moving
And now my aeroforce scan gauge took a crap so now I can't read icp or duty cycle
Old Nov 27, 2011 | 05:22 PM
DRRXR's Avatar
DRRXR
Have some one check the fuel presure at the schrader needle valve while you crank it. Use a cheap tire gauge and post the fuel line pressure. Also this isnt a bio or veggy convertion is it?
Old Nov 27, 2011 | 05:52 PM
arkredneck's Avatar
arkredneck
This truck runs on straight #2 I'll find a gauge and check it
Old Nov 27, 2011 | 06:03 PM
coreylasalle
here is some wiring diagrams Help!! Need 97 f350 wire diagram for inside - Ford Powerstroke Diesel Forum
post 5, there are a bunch of schematics, 3 that are "engine distribution" ones that have the engine wiring harness, idm, and pcm.
are you still using the New pcm? or did you go back to the original?
Old Nov 27, 2011 | 06:07 PM
arkredneck's Avatar
arkredneck
I'm using the one out of spare parts truck along with it's idm along with a CPS from the running dd truck
Old Nov 27, 2011 | 06:12 PM
  #28
coreylasalle
did the parts truck run? if it does id say put the dd pcm and idm in it to see if they were actually bad or not. if the dd indeed had a bad pcm, when you got it started maybe what ever caused the pcm to go bad, caused the partstruck pcm to go bad, is that the same time the scanner stopped working? did the scanner die or did it stop communicating ?
Old Nov 27, 2011 | 06:22 PM
  #29
arkredneck's Avatar
arkredneck
I got 3 trucks the parts one is a dd one is a big toy and parts truck is not running But when it was parked it did run
The dd I already swapped CPS and all cps are good
I really don't wanna take the idm and PCM from the running dd just in case whatever is wrong with the toy truck frys parts on the dd
Old Nov 27, 2011 | 06:53 PM
  #30
coreylasalle
did you say if your truck smoked out the exhaust at all when attempting to start it?
id say its safer to put possible bad parts in a good truck. for example if you put a good pcm in a truck that may have a bad pcm, what may have ruined the bad pcm may ruin the good one as well, but if you do it the other way and put the possible bad pcm in a running truck and it no longer runs, you know its the pcm, with out taking the chance of having 2 bad pcms
are the pcms the same or do they have different codes?
