not running????
Old Apr 13, 2003 | 09:36 PM
idealtrucks's Avatar
idealtrucks
not running????
i recently put a 1976 360 in a 71 truck. i kept the electronic ignition on the engine and tried to hook it up. heres my problem: the engine will run as long as you have the key held over to the start position. but when you let go, it looses fire and the engine quits. i ckecked and i have power to the coil when the key is on so its not the switch. could the ignition module be bad?? or what?? please help
Old Apr 13, 2003 | 11:06 PM
Rat wagon's Avatar
Rat wagon
not running????
you have to hold the ignition over right? It would be the switch
I think,
Old Apr 13, 2003 | 11:07 PM
sparky's Avatar
sparky
not running????
Did you run two power wires to the module?
One gives 12 volts during "start" the other gives 12 volts during "run". Both wires go to the module 2 pin connector.
Old Apr 14, 2003 | 11:21 AM
idealtrucks
not running????
its not the switch, i tried a different one and it run the truck before i changed engines. i did also run two wires to the module. could i have them backwards?
Old Apr 14, 2003 | 12:01 PM
jwrboss302's Avatar
jwrboss302
not running????
No Power to the module in the run mode, could be at the module connector, wire back to ignition switch or ignition switch.
JWR
72 F250 Camper Special
70 Boss 302
banshee_man_96
Nov 22, 2018 07:20 AM
claycomotrucks1991
6.2L V8
Oct 4, 2013 05:13 AM
thejim42
Sep 13, 2013 12:56 AM
69BOSS429HEMI
Electrical Systems/Wiring
Mar 22, 2013 06:41 PM
texasag00
2004 - 2008 F150
May 20, 2012 02:28 PM
