Tach sensor=tranny problems?
Old Nov 22, 2011 | 02:09 PM
ihf-350's Avatar
ihf-350
My tranny started acting up again this time the tach is going to 0 at idle and goes back up when I accelerate could the irratic shifting be caused by the tach sensor?
Old Nov 22, 2011 | 02:54 PM
whenry912's Avatar
whenry912
Assuming you have an E4OD, then yes, a malfunctioning tach sensor will cause all sorts of transmission gremlins. You can try to clean it up, check the electrical connections etc, but you will probably have to replace it.
Old Nov 26, 2011 | 12:16 AM
ihf-350's Avatar
ihf-350
I found a thread on here that told me how to test the sensor today any it tested bad so I went to the dealership and paid $75 got a new one and now it shifts like a dream for now lol till the next sensor goes out wonder which one that will be
Old Dec 30, 2011 | 05:50 PM
ride_gnu's Avatar
ride_gnu
Still got those test instructions? I went ahead and scoped mine, same test as the VSS and the wave form is totally erratic with snares all over the place, which would mean the teeth are damaged? Or could this because the teeth are on an angle to the magnet?
1972RedNeck
21
Mar 21, 2015 02:07 PM
gumper 123
May 17, 2010 09:58 PM
trooperkelly
Jan 14, 2006 08:29 AM
