Bad Tach Sensor?
Old Jan 10, 2006 | 09:40 AM
trooperkelly's Avatar
trooperkelly
Bad Tach Sensor?
A problem just popped up, at idle my tach will drop to zero rpm and then
tranny flashs error. When i idle up tach works and error goes away, also
when i take it out of over drive tach works fine and no error code. This
problem is not occur 100% of the time but is increasing in frequency.
Thanks in advance.
Old Jan 10, 2006 | 11:15 AM
modular2v's Avatar
modular2v
my tach will sit at 0 at idle then when i start to take off it pops up...mine is 5spd though, i think it is a bad sensor
Old Jan 14, 2006 | 07:55 AM
jqp00002's Avatar
jqp00002
I have a 1991 F-250 7.3L. My tach stopped working and sent the transmission into limp mode. This caused extremly hard shifts. The sensor is easily replaced and and may help end the transmission error codes.
Old Jan 14, 2006 | 08:29 AM
deanj's Avatar
deanj
the tac sensor is located by the oil filler, I think it is 1.1/4 nut. You can take it out and clean the pick up, but will probably have to replace. If the trans is acting up (going into limp mode) do not run to long, as the pump increases pressure to compensate. This can lead to a new T/C.
