Factory Tach question?
Old Apr 13, 2003 | 08:14 PM
alpine's Avatar
alpine
I found a gauge cluster at a local Junk yard that has a tach. My 84 didnt come with one, and has the idot lights on it. Would there be a way to hook up the tach in my truck? Just dont wanna buy it and have it not work.
Thanks,
Alpine
Old Apr 13, 2003 | 08:22 PM
Franklin2's Avatar
Franklin2
See if any of this helps
https://www.ford-trucks.com/forums/s...t=factory+tach
Old Apr 15, 2003 | 07:14 AM
82F100SWB's Avatar
82F100SWB
The factory tach is wired as follows: C terminal: coil -
B: Switched power, on it ACC. and Run. G: Ground 8: cyl. switch, ground for V8, leave ungrounded for 6 cyl.
For your truck, the easiest thing to do would be to put the tach in your instrument cluster and wire it up instead of trying to use the factory wiring due to the difference in connector plugs and the significant amount of re-wiring required to lose the idiot lights.
Evan
