no elecical power
Old Apr 14, 2003 | 12:57 PM
belugas's Avatar
belugas
no elecical power
hi first time here
i have an 84 f150 with a 300/6. no headlights or power to ignition.
new battery alternater is good (had checked) new starter relay.
i,m stumped any help
Old Apr 14, 2003 | 02:10 PM
Broncomule's Avatar
Broncomule
no elecical power
Check all of your fusible links.
Old Apr 15, 2003 | 11:34 AM
belugas's Avatar
belugas
no elecical power
thanks got it going was a connection. but now it ildes but runs real rough it also back fired could the timing chain have jumped.
thanks
Old Apr 15, 2003 | 12:16 PM
desperado_18_2000's Avatar
desperado_18_2000
no elecical power
300 sixes don't have timing chains, like other engines, they are gear driven, cam to crank.
If its idling rough, you've either got a vacuum leak or you are running really really rich and the motor is flooding. Possibly your coil is bad and causing the misfire. Its also possible that the pickup inside the distributor is going also, as this will cause a weak spark/no spark condition and a very rough idle, like its idling on 4 cyls instead of six.
To check for a vacuum leak, get some carb cleaner, or just some soapy water in a spray bottle and spray it on all of your vacuum lines and around the intake/carb.
The carb cleaner will increase the idle of the truck ,and the soapy water should be drawn in so you'll see the bubbles/water dissapearing.
As for adjusting the carb itself, it has one main idle adjustment screw on the passenger side of the carb, facing towards the inner fender. You need to adjust this till you get the best idle possible at the highest rpm. This is called lean best idle.
Hope this helps ya!
