What do you think
Old Dec 10, 2011 | 10:03 PM
danr1's Avatar
danr1
My diagram shows a should be a Red-lt blue wire "Start" power to clutch interlock/jumper and on to fender mounted relay (common/consistent this series).
Then the only wire that should have any power in it with key in "ACC" position (your model would/should have) is a Black-Lt green wire.
Have them two, the black-lt green and Red-Lt blue wires been swapped position on switch (unlikely but hey who knows) or crossed by someone when adding remote starter or like accessory? Might have been removed before you bought it?
Does it have a remote starter installed on it now?
If so it would explain why the starter engages in the accessory position, or you have those two wires fused with each other IE; melted right to one another at some point after the ignition switch.
Old Dec 10, 2011 | 10:04 PM
Bundy4825's Avatar
Bundy4825
When the truck is in the ON position the truck cranks and continues to crank even when the motor has started it wont crank in the ACC position only the On postion
Old Dec 10, 2011 | 10:11 PM
SideWinder4.9l's Avatar
SideWinder4.9l
If its doing that...Then the starter isn't dis-engaging....
The Bendix in the starter sounds like its hanging....Which is cause by the armeter becoming magnetized.....
Part # 11350 is suspect....Of being magnetized...
96bigblueford
6.7L Power Stroke Diesel
20
Jan 13, 2018 06:27 PM
ridecolby
Aug 11, 2009 07:51 PM
Rexman
Nov 27, 2006 04:31 PM
sanssoucimike
1978 - 1996 Big Bronco
Dec 21, 2005 12:38 AM
Gates
Apr 19, 2003 05:55 PM
