front cover passages
Old Nov 21, 2011 | 08:38 PM
1973dieselhighboy's Avatar
1973dieselhighboy
the passage that is circled in red were does this run to and what is its purpose. the one circled in green i am guessing that it is the oil supply for the resivoir, if that is not then what is it, the hole that is next to the hpop inside the cover on the left side were the pump comes threw the cover were does it come from and whats its purpose
Old Nov 22, 2011 | 06:14 PM
1973dieselhighboy
bump anyone know
Old Nov 22, 2011 | 07:45 PM
F350-6's Avatar
F350-6
Well you can go with the old fashioned diagram (for the later years) that will give you a general idea.
Another, more interesting read is here https://www.ford-trucks.com/forums/8...ml#post7013034
It's from the SD section so there are a couple of minor differences in things like the screen he talks about, but the holes and flow are described in better detail.
Old Nov 22, 2011 | 08:32 PM
DRRXR's Avatar
DRRXR
Post Heres a little more
Just a tad more
DIAGRAM
and ANOTHER
Old Nov 22, 2011 | 11:02 PM
1973dieselhighboy
so from what i got from the thread that was posted the one that is circled in green is the hpo resovoir supply passage, the one in red is a return from the hpop and dumps into the gear area or does it go into the resovoir again and the hole by the hpop mounting hole is also a return but sprays on the gears for lube
bmoore79
May 28, 2021 12:43 PM
tiny1
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Oct 13, 2017 12:00 AM
gcozmo
2004 - 2008 F150
19
Aug 12, 2009 08:59 AM
Monsta
Jan 9, 2004 07:03 PM
