choke release
Old Nov 21, 2011 | 02:14 PM
Dave Lloyd's Avatar
Dave Lloyd
choke release
I haven't had any previous problems with my 86 F250 carburator until today when the choke decided it wouldn't return the engine to a normal idol. I looked at other posts about problems with automatic chokes, understand a few trouble shooting suggestions but wondered if there is anything unique to the standard Ford straight 6 engine and carb I might not be aware of. Any suggestions out there as to where I should start checking? I assume the choke is integral.
Old Nov 21, 2011 | 04:38 PM
billt28's Avatar
billt28
Usually the choke is adjusted by the spring inside the black case at the top of the carb. Theres also the fast idle adjustment at the back of the carb, near the idle adjustment screw.
Old Nov 21, 2011 | 07:20 PM
Sw1tchfoot's Avatar
Sw1tchfoot
If it just stopped working out of the blue then you might want to check if you are getting power to the terminal at the choke cap. On a stock setup I believe you need to have the engine running to check it for power.
But first you might want to make sure that it is actually the choke that isn't coming off and not just something else inflating the idle speed. Remove the air cleaner and see if the choke flap opens or not after the engine warms up. If it does open and function correctly then you probably have a vacuum leak or something bumping up the idle speed.
Old Nov 22, 2011 | 05:20 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If not the choke, then a vacuum leak or stuck advance mechanism.
44nneedit
Feb 28, 2018 01:43 AM
Heesman
Sep 5, 2014 03:00 PM
nuwave
May 31, 2007 09:06 PM
65CJ5
Aug 17, 2004 10:59 AM
com4tablynumb
Jan 3, 2003 10:47 PM
