6.0 acting weird
Old Nov 21, 2011 | 07:36 AM
simsbud's Avatar
simsbud
6.0 acting weird
I have a 05 f-250 with the 6.0 turbo spools up way high when I first start driving it like 20+ pounds of boost and no power then you will feel it all of a sudden gain power ans the boost will drop off, but after I take off from a stoplight after the turnover calms down it has very low boost until I am in high gear then it takes off, any ideas what could be wrong? I've cleaned the vgt the ebt censor tube,
Old Nov 21, 2011 | 07:41 AM
simsbud's Avatar
simsbud
Where it says turn over in the post its supposed to say boost there, damn auto correct on my phone
Old Nov 21, 2011 | 11:26 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Could try cleaning map sensor and hose also. Passenger side small hose from intake to sensor on th firewall. Sounds like maybe turbo is still sticking or maybe VGT solenoid. Do you have any gauges or ScanGauge? Would be a good idea to check for codes. You can have a code without a CEL.
Old Nov 21, 2011 | 12:04 PM
simsbud's Avatar
simsbud
I had an issue about two months ago where my map hose was clogged n It threw the icp code so I replaced ot and cleaned the map hose then
flkeysff
Jul 13, 2019 08:11 AM
7.3stroker2
Sep 14, 2016 01:37 PM
Captn B
Jul 1, 2015 08:24 AM
teague350
Sep 30, 2011 04:49 PM
mollikate
Feb 6, 2008 01:36 PM
