C6 Plumbing Help??
Old Nov 21, 2011 | 12:54 AM
bruno2's Avatar
bruno2
C6 Plumbing Help??
Does anybody know which connection is the out and which one is the in? I need to hook up my tranny cooler and I cant remember which port is the supply and which is the return. Seems like the fitting at the front by the pump would be the out going one that would supply the cooler and the one in the rear would be the return line?
Then again are there seperate connections for the ones that go to the radiator and ones that go to the tranny cooler? I need some diagram help for plumbing this thing.
Thanks for any and all help guys!
Old Nov 21, 2011 | 04:20 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...ler-lines.html Click on this link.
Should have said that the outlet from the trans pump is piped to the top port on the engine radiator cooler. The lower port on the rad cooler is piped to the inlet of the aux trans cooler and the outlet of the aux cooler is piped straight to the trans return port.
grec-o-face
Jul 14, 2012 01:42 PM
82f3504x4
May 12, 2008 06:25 PM
tnwill
Oct 26, 2007 04:35 PM
fordtruckn
Jul 28, 2006 11:02 PM
jinxed
Mar 19, 2006 02:22 PM
