MAF or Speed Density
Old Nov 20, 2011 | 08:52 PM
cowman435's Avatar
cowman435
Hi i have a 1989 California ford ranger with the 2.9 but that engine is out of a 1988 Bronco 2 aslo a California emissions vehicle and i was wondering would the engine from the bronco have MAF and did the 1989 ranger have MAF. also how would i determine which system it uses? Thank you very much for your help.
Old Nov 21, 2011 | 08:28 AM
pawpaw's Avatar
pawpaw
If you don't get a reply on this forum, maybe try the FTE Bronco, or 3.0L Vulcan engine forum, bet someone there has your answer.
Old Nov 21, 2011 | 10:27 AM
KhanTyranitar's Avatar
KhanTyranitar
Few Fords used speed density. If your setup has a sensor in the intake near the air box, you have a MAF setup. Speed density uses a MAP sensor, which uses a vacuum source for reference.
Old Nov 21, 2011 | 11:28 AM
cowman435's Avatar
cowman435
Okay i see well there is a sensor where the intake hose connects to the intake, but not near the air box. So if im right it is speed density?
Old Nov 21, 2011 | 11:58 AM
KhanTyranitar
Please post a picture of what you are seeing. It would be very unlikely that a CA vehicle would use speed density, MAf was usually preferred where strict emissions are important.
Old Nov 21, 2011 | 12:14 PM
cowman435's Avatar
cowman435
Okay http://i744.photobucket.com/albums/x...1-21100944.jpg
Old Nov 22, 2011 | 09:38 AM
KhanTyranitar
Ok, that is a speed density setup, no MAF sensor to be seen. The MAP sensor is likely behind something or just out of frame. Fairly clean looking motor, cobwebs aside. The donor vehicle would likely have the same setup, but since they are the same motor, if you encounter anything that is a little different, I'm sure you can swap parts.
Old Nov 22, 2011 | 10:25 AM
cowman435's Avatar
cowman435
Thank you for very much for you help
nekkidwelder
Mar 1, 2010 06:56 PM
TallPaul
Apr 20, 2007 12:06 PM
streetbeast
1978 - 1996 Big Bronco
Mar 23, 2006 11:11 PM
Duderoy
May 10, 2003 03:35 PM
black-bronco
Feb 26, 2003 06:14 AM
