Sponsored by: Real Truck
v-10 ??
Old Nov 20, 2011 | 04:13 PM
vmj's Avatar
vmj
v-10 ??
I was just given a ford f350 with a v-10. It has sat for 1.5 years. Got it running (fuel pump) But runs so so. Other then change the oil what else should i do? I think its a skip in the motor. thanks
Old Nov 20, 2011 | 04:27 PM
kd0axs's Avatar
kd0axs
I would go ahead and change ALL fluids, not just the oil.
Change spark plugs, also check the coils and boots (one coil and boot on top of each spark plug) as these are a relatively common failure on these engines.
Drive it and get all that old gas out of the system, change the fuel filter, and run a good injector cleaner through it. (Techron seems to be highly recommended)
Is the check engine light on? Check for codes even if it's not on as there could be stored codes.
Old Nov 20, 2011 | 04:37 PM
vmj's Avatar
vmj
no check engine light. what do u look for on the coil boot?? it hasa 1/4 tank of gas, i added 3 gal of fresh gas. thanks
kd0axs's Avatar
kd0axs
Also check for vacuum leaks, especially if you have the Electronic Shift on the Fly (ESOF) 4 wheel drive system. If it has a switch on the dash for 4WD, you have ESOF. If it has a lever on the floor, you have the manual 4WD system. With ESOF, the hub locks are vacuum controlled and those vacuum lines like to break.
Old Nov 20, 2011 | 04:43 PM
vmj's Avatar
vmj
i have the manual 4x4
Old Nov 20, 2011 | 04:58 PM
barthel's Avatar
barthel
Cracks, splits, anywhere it could be grounding to the head. It's actually just easier to replace them when you change the plugs, they're only about 3 or 4 bucks a piece. Cheap insurance.
Clean your throttle body and MAF while you're at it.
Old Nov 20, 2011 | 05:00 PM
Kajtek1's Avatar
Kajtek1
Depends what conditions the truck was kept on.
I restarted a diesel motorhome that was parked under California oak for 7 years and all I had to do is bring fresh batteries and pump the tires.
2 years old gasoline in pressurized tank should be good, but it is possible that condensation water is present in the tank. I would drain the tank and put fresh gas to start with. Drive with spare fuel filters in the truck for a year to come.
xhrj001
Nov 19, 2016 06:22 PM
champlainl
Jan 12, 2014 08:22 AM
pop4233
Aug 20, 2013 08:57 PM
justgunner
Modular V10 (6.8l)
May 7, 2012 05:57 PM
BIGBEAR6
Modular V10 (6.8l)
Dec 21, 2003 08:08 PM
