Bodywork Bloopers
Old Nov 23, 2011 | 08:59 PM
chappys4life's Avatar
chappys4life
Originally Posted by Jeff and Nicolle
Does anyone use lead anymore?
Some people do but its definitely a dying art. You can still get the supplies through eastwood.
Old Nov 23, 2011 | 09:55 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Maybe I am a nutcase, but I have wanted to experiment with lead filler, for a long time. Probably won't but...
Thanks!
Old Nov 23, 2011 | 11:22 PM
bobj49f2's Avatar
bobj49f2
I worked near a body shop owned my an old guy who still used lead on a lot of cars, even newer ones. He made it look so damn easy. He'd tin the metal, warm the lead bars just to the point of melting and then slap gobs of lead on the side of the car and smooth it out with his hardwood paddle coated in bee's wax. He'd flash the lead with his torch just to soften it and smooth it out. Looked as easy as frosting a cake. I tried it numerous times on my own, even bought a kit the huckster at the swap meet said anyone could use. I never was able to get the lead to stick. That's why I use plastic filler, a lot easier to use, a lot cheaper and easier to get. If body work is done correctly you only need a thin layer and with the modern formulas it should last a life time.
Old Nov 25, 2011 | 04:47 PM
55paneltrk.'s Avatar
55paneltrk.
some good work here
Just getting too this part of the old panel now.
was sort off saving the worst to repair for last.
Old Nov 25, 2011 | 06:16 PM
Jeff and Nicolle
Yeah it's not really that I want to fill my truck, or future projects, with lead. I am sure that as you said Bob, the plastic fillers today are fine and that's what I have worked with in the past. It's just about the art form dying and even beyond that, the nostalgia that goes along with it.
Old Nov 25, 2011 | 06:21 PM
Jeff and Nicolle
Wow, nice patch job huh? I am sure you can handle it though, as I notice Cleco fasteners. Those thing are awesome, I used them when I was in the Navy, working on aircraft. Wish I had some!
Old Nov 26, 2011 | 01:59 PM
Lakotas53's Avatar
Lakotas53
Jeff you can still get tthe Cleco fasteners from several places. Eastwood has them. So does McMaster Carr.
Old Nov 26, 2011 | 02:21 PM
bobj49f2's Avatar
bobj49f2
To add to my previous post about my Frankenstein panel. I am in the process of cutting it into little bite sized pieces and when I took the rear inner panels off I found one of the previous owners solutions to seal the bodies from leaking. He jammed old gloves and a towel or rag into the seams. Good idea!! Now I know why the rear fenders were loaded with plastic mud.
Old Nov 26, 2011 | 03:52 PM
Jeff and Nicolle
Yeah I know but I would have to actually BUY them...
I know...tight huh?
Old Nov 27, 2011 | 05:00 PM
theodore/teddy's Avatar
theodore/teddy
Refyred
Jeff get more for your buck here. Cleco / KwikLok Temporary Fasteners I have not purchased from them my self!
Old Apr 13, 2012 | 01:01 PM
DadOh1's Avatar
DadOh1
Did you know that Bondo can be over 5 inches thick?
One of the first things I did when i got my '54 was to pull off the grill because it looked like it needed some straightening (and I'm one of those weirdos that love the Fangs). When I did I found that the grill had been smashed in pretty thoroughly at one point. But, instead of pounding it out even a little bit (the metal was fine!), the PO made an art project out of it, by completely recreating the front shape of the 54 grill out of bondo by hand!
I gotta admit, he did do a fairly good job of it, but still....
(Sorry for no pix, this was before I discovered FTE - - I just laughed and figured no one would care OR believe me....)
reamer
Oct 2, 2016 03:01 AM
jmadsen
Nov 4, 2008 11:31 AM
jmadsen
Paint & Bodywork
15
Jun 27, 2008 05:21 PM
bobj49f2
Sep 11, 2006 08:32 PM
svooom
May 30, 2006 01:37 PM
