Sponsored by: Auxito
Trailer hitch lighting issue
Old Nov 19, 2011 | 04:22 PM
fetchitupup's Avatar
fetchitupup
New to the forum. I am not getting running lights at my 7 pin connector on my 1997 F150 truck. I have not had the issue before, replaced all the lights on the trailer and everything works when I hook it up to my buddy's truck. Put a meter on the 7 pin and not getting any voltage at the connector. Getting continutiy from one side of the connector to the other so it is not there. We are baffled.
thanks in advance for help.
high and dry until we get it fixed.
Old Nov 19, 2011 | 06:18 PM
steve(ill)'s Avatar
steve(ill)
fuse box under hood by air inlet box-- #1 fuse- trailer lights. Look in the operators manual on road side emergencies.
https://www.fleet.ford.com/maintenan...ls/results.asp
Old Nov 19, 2011 | 06:49 PM
coatit's Avatar
coatit
or could be a relay also in that same box or under dash under radio
Old Nov 19, 2011 | 07:52 PM
fetchitupup
Thanks
Thanks guys, I will check them out. I checked the fuse in box under the dash, but not under the hood.
Old Nov 21, 2011 | 10:23 AM
fetchitupup
thanks for the help- problem solved
Found the culprit, blew a fuse.
h2oski
1997 - 2003 F150
Mar 16, 2017 09:49 AM
Splatts
31
Dec 29, 2012 07:59 PM
ron2681
2004 - 2008 F150
Jan 12, 2012 04:09 AM
RonSeg
All Things Towing
Jan 20, 2004 06:18 AM
guitar4him
Mar 13, 2002 04:32 PM
