steering help! ASAP
Old Nov 18, 2011 | 11:24 PM
idahoFORD350's Avatar
idahoFORD350
steering help! ASAP
trying to fix the play in my steering, took off the steering wheel, disconnected the ujoint for the (tilt wheel). But does anybody know how in the hell I can get this front bearing out without complete dissassembly the column??
Old Nov 18, 2011 | 11:25 PM
idahoFORD350
this is in a 92 f350 btw
Old Nov 20, 2011 | 01:00 AM
idahoFORD350
...alright the answer to my question is.... NOOOO, after spending the day figuring and figuring you must take the whole column apart. Key note in this model in order to pull the shaft out of the housing you must disconnect the bottom wiring harness for the ignition, then unbolt the white box it plugs into it...why because well you'll find out if you must change the bearings (there are in fact three upper bearings 2 small (same size but slightly different bearings) and 1 larger bearing. If anybody reading this has to change bearings for the 92' model F350 by all means MESSAGE me and i'll help you if you need it
...with that said swapping in new bearings did not fix my steering play, more diagnosing to do i guess
Old Nov 20, 2011 | 07:30 AM
Encho's Avatar
Encho
The Southernmost Mod
But why take the steering wheel off? is it the SW itself that has play? then yes, you need to get to that bearing (seems you already did), there is also a little u-joint down there in the column, you should inspect it. But my guess is the issue is in the steering box.
Old Nov 28, 2011 | 10:49 AM
idahoFORD350
most certainly could be...some people who have posted said they had similar play in the wheel and it was caused by bad bearings, that was definately not the case for me, I am planning on replacing the tie rods and I might also have to change out the gear box, I have never replaced a steering gear box have you? if you have any advice or helpful tips
Old Nov 28, 2011 | 11:04 AM
Encho's Avatar
Encho
Have a read here: https://www.ford-trucks.com/forums/1...x-rebuild.html
Old Nov 28, 2011 | 12:27 PM
Kemicalburns's Avatar
Kemicalburns
look into getting a redhead gear box. ive heard to many folks by a new box from an autoparts store with the same sloppy issues that the current box has. Tierods,balljoint will all play a roll in bad steering. take care of those issues first before proceeding further
Snowseeker
37
May 31, 2017 04:48 PM
BM19
19
Jul 26, 2016 07:57 PM
damianbreaux
Jul 3, 2015 08:14 PM
Mikeleew
Dec 25, 2004 09:20 PM
