Sponsored by: Real Truck
2000-2004 leveling kits - front settled down?
Old Nov 18, 2011 | 06:25 PM
sandman3510's Avatar
sandman3510
Hi all, i've been reading tons of posts on leveling kits and i'm almost blue in the face from all the reading. I have a 2000 v10 CC shortbox 4X4 that I'd like to "lift" using Zone's 2-1/2" kit. I'm a bit nervous though, because I don't really want more than 2-1/2" of lift for a couple reasons. 1) because I still need to get through a 7' garage door, and 2) I don't want to cause alignment problems.
I also want to lift the back to maintain factory rake, either with a 4" block or 5" block, depending on how much the frontend comes up.
I called zone and they said before I install their kit leaving the bottom leaf out (2" lift), to drive it a little bit and let the front end "settle down". For those of you with the zone kit or tough country kit (similar style kits) that started out with over 2-1/2" of lift, where are you sitting now? Has it settled down any?
Did you drive it right away without getting it aligned?
Sorry for all the questions, I just want to do this right.
Thank you,
Pat
Old Nov 18, 2011 | 07:47 PM
F350-6's Avatar
F350-6
I wouldn't look for it to "settle down" much, if any. You can drive it after you install the leveling kit, but you need to get it aligned. If you don't, expect to start eating front tires and the truck to not steer the same.
Old Nov 18, 2011 | 08:23 PM
GOT-DRT's Avatar
GOT-DRT
I have a 2002 f350 v10 with a 2-1/2 in.leveling kit with 33-12.50 and fits in my garage my door is 7th high
Old Nov 19, 2011 | 09:03 AM
sandman3510
Can you do me a favor? can you measure the height of your wheelwells from the floor?
My truck measures 39" front/41" rear right now. Looks like I have about 5-6" to spare above the truck.
Thanks!
Pat
Old Nov 19, 2011 | 05:55 PM
GOT-DRT's Avatar
GOT-DRT
Thanks!
Pat
My front is 42-1/2 and the rear is 43-1/2
Old Nov 19, 2011 | 10:19 PM
SuperDutyScaler's Avatar
SuperDutyScaler
you dont need it aligned after a lift on a leaf spring truck. So far i installed lifts on my 2004 SD, dads 2000 SD, buddies 2003 SD, 78 K30 and never gotany aligned. just adjust the drag link so your wheel is centered after the lift is installed and your good to go.
tozir
2004 - 2008 F150
Jan 15, 2015 03:24 PM
mlem894
Jun 20, 2014 11:10 AM
Sleepsafe
Sep 8, 2009 10:55 PM
Still Smoking
2004 - 2008 F150
Oct 7, 2008 11:05 AM
Dean88
15
Dec 3, 2007 11:02 AM
