flathead 6... no compression
Old Nov 18, 2011 | 04:05 PM
badger_hound's Avatar
badger_hound
No compression for 3 cylinders of my 226. I'm guessing stuck valves as it sat with an open carb for years.
So, before I take the head off, I'm going to pull off the intake and exhaust manifolds so that I can get to the valve covers and hopefully see what's going on.
Some days you win, and some days you lose...
Old Nov 18, 2011 | 04:31 PM
brain75's Avatar
brain75
Any troubleshooting so far or just diagnostics?
I had 1 low cylinder, a ton of blow by, and hot exhaust.
It was suggested to me that I soak in seafoam overnight - did that, minimal help.
It was suggested to me that I soak in atf between overnight and a week - did that, help was better.
Haven't rechecked but the ATF calmed down the blow by and hot exhaust.
My plan is to drive it for a couple weeks then check compression again.
Another thing after you get it running is the "pepto treatment."
https://www.ford-trucks.com/forums/1...l#post10903921
The 3 above items are all a lot easier work wise than tear down and they might loosen the rings so they float again and get sticky valves unstuck.
Old Nov 18, 2011 | 05:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've got a flat V8 sitting in my garage that also got some water down the intake (it didn't make it to the cylinders, thankfully). I have the heads and intake off. The valves are sticking, but you'd never guess it from the valve chest or the cylinder deck.
No amount of anything is going to simultaneously get the rust out of the port, off the valve stems, and out of the guides. Removal and cleaning is the correct fix. Otherwise you'll just slowly wear out cylinders, valves, and guides.
Old Nov 18, 2011 | 06:28 PM
badger_hound
Thanks for the response guys. I pulled the valve covers and found out that I have 3 stuck valves. And they are pretty stuck - gentle prying didn't free them so I don't know how much good it would do to soak the cylinders with seafoam or ATF.
I may have to bite the bullet and pull the head.
One idea I had, though, was to put a spacer between the stuck valves and the tappets and crank the engine by hand in hopes the tappet 'extension' would help to pop the stuck valve up. But I don't know what kind of trouble I could get into by doing this... like maybe cracking the camshaft... any thoughts?
Old Nov 18, 2011 | 07:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Are the valves rusty, or gummed up, i.e., what is making them stick?
You're going to have to pull the head eventually.
Old Nov 18, 2011 | 10:18 PM
badger_hound
I'm not sure exactly why they are sticking. The valve chambers aren't THAT gunked up so it could be a rust issue. That said, the engine is not particularly rusty. This is how it looked when I bought it:
<a href="http://s1230.photobucket.com/albums/ee483/badger_hound/misc/?action=view&amp;current=DSCF8998.jpg" target="_blank"><img src="http://i1230.photobucket.com/albums/ee483/badger_hound/misc/DSCF8998.jpg" border="0" alt="Photobucket"></a>
If I have time this weekend I'm gonna pull the intake and exhaust manifolds so that I can get a better look inside (turns out I was able to get the valve covers off today without pulling the manifolds off).
I am not opposed to unbolting the head, in fact I'd like to. However, I am not looking forward to breaking off head bolts as this truck has been sitting for a while.
Old Nov 18, 2011 | 11:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by badger_hound
...I am not opposed to unbolting the head, in fact I'd like to. However, I am not looking forward to breaking off head bolts as this truck has been sitting for a while.
The trick is to use an impact wrench. If you can't, tighten the bolts a bit before removing them. Some people also smack the bolt heads with a hammer first, it relieves some stress.
Old Nov 21, 2011 | 01:34 AM
badger_hound
Well I managed to get the manifolds off yesterday. Two exhaust valves and one intake valve stuck, plus a mouse nest in one of the other ports, and another in the exhaust near the muffler! The rust and gunk don't look that bad on the upper part of the valves, so I may try again to pry them up from below after plugging up the ports and soaking the top of the stuck valves in some penetrant. I may try the ATF, thanks for the suggestion Bryan.
And thanks for the tip on the impact wrench Ross. I'm still leary about unbolting the head right now as I don't have a torch or mig welder handy to help extract the inevitable broken bolts from the block.
Old Nov 21, 2011 | 09:49 AM
Moto Mel's Avatar
Moto Mel
You might try some "Rust Buster" on the top side of the valve stems and let it soak for a day or two. Another trick we used in the marine industry for inboards that were under saltwater for up to 2 weeks was to flood the top end with DOT 3 brake fluid, after clearing all the water out. This was used prior to disassembly for a rebuild, but some customers would not or could not afford a rebuild and if the engine ran or would turn over with the starter they would take their boat and do whatever to get it running again. Some of them ran for years after being sunk for several days in Florida waters.
Old Nov 21, 2011 | 09:56 AM
brain75's Avatar
brain75
Kudo's should go to Ross on that one He's the one who suggested the ATF to me (I had heard of seafoaming before several times - but ATF worked better in my case thanks to Ross for the suggestion).
Old Nov 21, 2011 | 10:21 AM
ALBUQ F-1's Avatar
ALBUQ F-1
??? It wasn't me, at least as far as I can remember! (CRS) I'm a SeaFoam kind of guy.
Old Nov 21, 2011 | 10:54 AM
brain75's Avatar
brain75
Ross's advice is sound - even when it isn't his :P
I guess it was yamagrant and kenjh who suggested it.
https://www.ford-trucks.com/forums/1...o-step-in.html
Old Nov 22, 2011 | 01:18 AM
badger_hound
Some progress - I sprayed the stuck valves with WD40 earlier today and freed one exhaust valve with gentle prying from below. I need to find something to plug the other ports up with though before pouring in the ATF. I tried a round cork and an round rubber stopper but neither conformed to the square opening, which is about 1" X 2". Any ideas?
Old Nov 22, 2011 | 08:12 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think you need to flood them with ATF, just squirt some more on them each day. WD40 isn't a penetrating oil, just a water displacer. Are you thinning the ATF with acetone or diesel? Usually that's the idea. Patience is a virtue... Why not pull the head, and the valves?
Old Nov 22, 2011 | 09:37 AM
arctic y block's Avatar
arctic y block
ATF And Acetone mixed 50/50. The best penetrate there is.
filthy6
Feb 10, 2014 10:39 AM
Walle1danman
Jul 25, 2013 06:56 PM
ramarado
Jul 2, 2010 10:52 PM
72amcamx
May 24, 2007 05:37 PM
59'er F100
Mar 8, 2005 12:44 AM
