Modular V10 (6.8l)
Fuel pressure
Old Nov 17, 2011 | 08:24 PM
j2007's Avatar
j2007
Fuel pressure
Anyone know what the fuel pressure is supposed to be on an 06 3v V10?
Is there a test port anywhere? I am reading off of the obdII port about 5 psi, which seems low to me?
Old Nov 18, 2011 | 07:27 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, that is quite low. I know the 2-valve system uses 38-40 at WOT or the vacuum disconnected from the regulator, and 28-30 at idle.
BUT - the 3-valve system doesn't use a regulator, does it? the PCM has to regulate the pressure by pulse-width-modulating the fuel pump or something?
RSuperDuty13
Jun 25, 2016 08:25 AM
kevin206
Aug 18, 2014 11:05 PM
XSleeper
Apr 29, 2014 01:42 PM
slomafarms
1997 - 2003 F150
Oct 21, 2011 07:17 PM
Aerostar1
Aerostar
17
Feb 19, 2007 11:03 PM
