Sponsored by: Auxito
Fuel pressure regulator test?
Old Oct 21, 2011 | 12:11 PM
slomafarms's Avatar
slomafarms
Is there a way to test the fuel pressure regulator? Im buying a gauge in the morning to test the pressure. When i take the vac line off there is no effect on the idle or when i rev it, even with my finger on the end of the vac line.
Old Oct 21, 2011 | 01:13 PM
Bluegrass 7's Avatar
Bluegrass 7
Here's how it works.
With no engine vacuum applied 'hose off' and engine running, the regulator regulates to it's basic design pressure plus or minus some tolerance.
That pressure should be betwen 35 and 38 psi.
With application of engine vacuum through the vacuum regulator, the fuel rgulator has a diaphram that is pulled on. This will lower the outlet pressure to the fuel rails, about 5 psi +/-.
To test this function you can pull the hose off or use a hand vacuum pump to apply vacuum to the fuel regulator with the motor running.
To test for cold start fuel operation, install gage.
Turn key to run , observe gage reading. If 15 to 20 psi, return ignition to off and do it again several more times. If the gage climbs toward full pressure with several on-off cycles, the pump is picking up the pressure normal
Observe the results on your pressure gage hooked to the fuel rail test port.
To finish off, the pump pressure can be as high as 100 psi that is regulated downward by the regulator.
A hint; if the motor runs out of fuel from an empty tank, after putting fuel in, cycle the key to run 5 or 6 times. This will prime the system back to normal.
Good luck.
Old Oct 21, 2011 | 06:55 PM
jirwin's Avatar
jirwin
Good luck.
Is there pictures of this test. I seem to be able to do just about anything with pictures. Where is this test port and what type of guage. Sorry, I am a noob, but I did my fuel filter and changed all my cop's myself with the help of pictures on this forum.
Old Oct 21, 2011 | 07:17 PM
kbsupercrew's Avatar
kbsupercrew
Its on the fuel rail between cylinder 3 and 4 ( back two on passenger side) you need a fuel pressure gauge with the fittings to connect, looks like a tire valve ,i always just cover it with a rag and with a tiny scewdriver release the pressure,like letting air out of a tire, as im covering it with a rag to absorb the gas as it relieves then connect the tester, the tester should has a bleed down line on it to relieve the pressure for disconnection
88/89bronco
1978 - 1996 Big Bronco
Jan 24, 2017 05:42 PM
1992FordF150Custom
19
May 25, 2014 01:03 PM
ham-n-swiss
Jun 25, 2009 02:00 PM
Aerostar1
Aerostar
17
Feb 19, 2007 11:03 PM
rangerchief
1983 - 2012 Ranger & B-Series
Feb 27, 2005 09:59 PM
