Fogging
I was reading several pages back and saw some references to "fogging" your motor by removing the manifold intake line off the master cylinder and pouring some Seafoam down the line and letting it sit and then starting the truck...
A few questions on this procedure - - first, is that the correct procedure and second, exactly what does this accomplish???
Les
Everything you need to know plus videos of how to use.
I have never used it in the intake, i tried the spray once and didn't get it all the way in so it leaked down the air filter tube.
I run a can through the gas tank a few times a year and run some through the oil on the first 2 oil changes I do on any used vehicle I buy. I also use it as a fuel stabilizer on my jet skis, quads and for the fuel station tank on my toy hauler.
The best way to keep the engine clean is to "get on it" once in a while.
Any time I've taken apart one of my engines over the years, it's always nice and clean inside.
Use a good brand-name oil, a brand-name gasoline, and keep up on the regular maintenance.
There's NO reason you need to have your engine ingest liquids that can hydrolock it or otherwise loosen deposits that will damage something.
Over the summer I was noticing that I didn't have the pep that I remembered. I ran 2 bottles of the fuel system cleaner through it. Each on separate tanks. As Krewat mentioned... "Get On It" a little while running something through the fuel. Let it scream! Now, I'm back to what I remember... although now I'm using more gas because I like hearing that V10 in the high rpms.
Just my 2cents...
IMO it actually caused more trouble (in my particular case).
I agree with Art, "if it 'aint broke - don't fix it"... I do believe in the Techron products though - haven't failed me yet.
To deviate from this post a bit and reference my other post regarding the fuel pump relay - - -
When I was pulling my #9400 Travel Trailer in the Rockies last year I thought the performance could have been better as I was down to 20 MPH in first gear crossing Loveland Pass (12,000') but that may have been typical - I don't know... Maybe there is/was a connection between that towing performance and the intermittent starting issue now...
But this intermittent starting issue has been plaguing me for almost a year now - it was fine all summer long, but now that it's cold again, it seems to be acting up again... When the truck won't start, I can hear the fuel pump relay clicking, but I don't hear the fuel pump charging the fuel line and this is consistent...
When the truck starts, I hear both the relay and the fuel pump... When the truck won't start, I hear only the relay and NO fuel pump sound... Since I replaced the relay, the truck has been starting fine...
I took the old relay and put in the freezer for an hour or so and then checked it's operation with a 12 volt power supply and DVM - it worked fine... I removed it's case and looked at the contacts with a 20X jewelers loop and they look like brand new...
I wonder if the power for the fuel pump is routed thru the ignition switch after the relay but before the fuel pump??? If in fact this is the route the power takes, I could have an intermittent ignition switch rather than an intermittent fuel pump...
The reason I am suspecting the fuel pump is two fold - I can hear the fuel pump relay activate all the time but not the pump and I'm wondering if last years poor towing performance in the Rockies is somehow related to a weak or otherwise dying fuel pump??? I dunno - just thinking out loud here...
Sorry - I really went off topic with this last post but it is my effort to try and explain how it all ties together. and the way I'm thinking..
Les
Also remember you are down quite a bit of power due to the thinner air at that 12,000' altitude. A naturally aspirated engine like the V10 can lose a a good percentage of its power output. Forced induction reduces the power loss quite a bit they suffer some from the thinner air also. Down to 20mph towing 10k lbs sounds a little slow but I don't know the exact road conditions or how your truck is configured.
Would be nice to maybe semi permanently install a fuel pressure gauge you can monitor while driving to see if any screwy happens.
My truck is a 2000 2v with a full Banks kit (including Trans Command and Automind) with a 4R100 and 3:73LS rear axle... Other than the Banks kit the truck is pretty much bone stock...
I do have a fuel pressure gauge and have been thinking about reinstalling it and driving around a bit to see what things look like...
Thanks for the comments,
Les
I drove Joe's Ex and quite frankly, I thought my 250 with the Banks did a lot better overall...
Les
