Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Diesel prices
Old Oct 17, 2012 | 09:35 AM
  #31
preppypyro's Avatar
preppypyro
I would own one if I could build it properly. It would fit my long distance trail riding, and utility purposes great.
Guess a guy could always make something up so it would start in the coldest weather. Propane heater tied into the cooling system maybe. We had diesel rigs in northern alberta that had similar systems so it would work. Keeping it light would be the trick there though!
Old Oct 17, 2012 | 11:00 AM
  #32
Fomoko1's Avatar
Fomoko1
If diesel quads are liquid cooled then a block heater would work.
Old Oct 17, 2012 | 10:59 PM
  #33
preppypyro's Avatar
preppypyro
They are, and sleds would be as well.
Old Oct 18, 2012 | 07:58 AM
  #34
96sherm's Avatar
96sherm
I think the hp/lb ratio would always be a struggle with a diesel in a sled, similar to the problem with a 4-stroke. The only way to get 2-stroke-ish power in a 4-stroke sled is to turbo it, or up the displacement, both adding weight and cost. Put the same $$$ into a two stroke and I think you could make it as long lasting as a 4-stroke, but with way more power. I'll keep my oil burner for a while yet
Old Oct 18, 2012 | 10:46 AM
  #35
preppypyro's Avatar
preppypyro
Yes Ill keep my 2 smoker as well.
The power a turboed diesel would make, would probably make that hp/lb difference pretty good!
The weight and the cold starting would surely be the issues though.
Might make a great utility sled?
akpwrstrk
190
Mar 13, 2026 06:42 AM
Kep4
Dec 5, 2008 04:32 PM
Cannonball01
Nov 4, 2005 05:15 AM
dragula
Apr 19, 2005 09:22 PM
labenske
Dec 31, 2004 06:03 PM
