engine run-on
Old Nov 16, 2011 | 10:41 PM
MR-Q's Avatar
MR-Q
engine run-on
anyone had problems with engine run-on. i'm having problems with run-on after engine is turned off and a bad smell after this occurs,from excess fuel burning i would think. the timing seems to be right and it seems to only happen after it gets hot. is there any solution. I'm not to mechanical minded but willing to have a go. sorry its a 351 cleveland with new holley carb, but was doing it with old thermoquad.
Old Nov 16, 2011 | 11:04 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
my jeep diesels from time to time... leaky carb letting fuel into the combustion chamber is my culprit.
Old Nov 17, 2011 | 09:27 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Idle speed too high is a common cause of this.
Old Nov 17, 2011 | 02:49 PM
Greyf100's Avatar
Greyf100
What's the timing set at?
What is your Idle speed (in neutral w/manual trans, P w/auto trans)
Did you set timing with a light, vacuum gauge, or by ear?
Is it hard to start? while hot? while cold?
How is your vacuum advance hooked up, if at all?
Old Nov 17, 2011 | 03:19 PM
Franklin2's Avatar
Franklin2
I agree also, you idle speed is set too high.
Old Nov 17, 2011 | 04:54 PM
MR-Q's Avatar
MR-Q
thanks for replies, i set the timing to 6 degrees before top dead centre with auto in neutral with vacum line to elect dizzy off carb with a timing light. i think idle speed sits around 750 but it fluctuates on this. it it hard to start when hot only sometimes which i think is starter motor problem as i can tap the starter and she fires. just have to invest in new one. i will have a look at idle speed when i get a chance. does the vacum unit on the dizzy need replacing. i have just bought a new manifold for it so i will pull all this gear out soon. migh buy a new dizzy and coil while i am at it.
Old Nov 17, 2011 | 06:52 PM
Greyf100's Avatar
Greyf100
idle speed while in D holding the brake should be around 550rpm. Which should put it right about where you have it now in N.
Is the vacuum advanced hooked to Full manifold vacuum or Ported Vacuum?
Old Nov 17, 2011 | 09:50 PM
Rogue_Wulff
750 is a bit high. If you have to keep it turned up that much to prevent it dying in gear, then you need to turn the key off while still in gear, then place into park.
Old Nov 18, 2011 | 09:34 AM
Gary Lewis's Avatar
Gary Lewis
As I think greyf100 is implying, your vacuum should be hooked to ported vacuum. IOW, it should only get vacuum when you open the throttle but not at idle.
85fordf150blue
Aug 3, 2011 12:08 PM
8525ford
May 1, 2010 01:37 PM
andrewasl
Jul 13, 2006 10:10 PM
Hellbore
May 23, 2006 05:22 PM
wideglide_smb
Jul 9, 2004 10:45 PM
