Fuse Tap ???
Old Nov 16, 2011 | 07:43 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Fuse Tap ???
when i get to install my new glowshift gauges i will need to tap into a switched 12V power and a constant 12V power from the fuse panel.
I found these two fuse taps...
Buy Bussmann ATM Fuse Tap BP/HHH at Advance Auto Parts
Buy Bussmann ATC Fuse Tap BP/HHA at Advance Auto Parts
the first link is for an ATM fuse tap and the second one is for an ATC fuse tap. which one do i need and what is the difference between the ATM and ATC?
thanks.
Old Nov 16, 2011 | 09:28 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
if you pull one of the fuses out,which blade type does it appear to be?
does it look as if our trucks use the "ATC" or the "ATM" blade type?
what do these blade types stand for?
Fuse (automotive) - Wikipedia, the free encyclopedia
Mini APM, ATM 10.9 x 3.6 x 16.3 mm 2, 3, 4, 5, 7.5, 10, 15, 20, 25, 30
Regular APR, ATC, ATO 19.1 x 5.1 x 18.5 mm 1, 2, 3, 4, 5, 7.5, 10, 15, 20, 25, 30, 35, 40
(atc)
Old Nov 17, 2011 | 11:09 AM
Rollin.IH.Coal's Avatar
Rollin.IH.Coal
oops, for my GS gages... i used the headlight switcher, you will find both there. for my switched tho i tapped into an ignition wire. thatway when i turn the key BAM!
Old Nov 17, 2011 | 02:33 PM
snaponprofile's Avatar
snaponprofile
Jam a wire in there and hen shove the fuse back in.
gnwalker
Electrical Systems/Wiring
Jan 28, 2014 11:49 AM
materthegreater
Mar 16, 2012 09:05 AM
E40
Sep 10, 2011 04:24 AM
Big Ruth
May 24, 2010 05:42 PM
Danny Stroup
Feb 3, 2010 06:16 PM
