Way to test the float?
Old Nov 16, 2011 | 04:42 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
Is there a way to test the float in the tanks I ran out of fuel the other day and I really don't want to repeat that and if it's no good I will buy another one I just would like to not have too! But like stated I will have to see if the float is good and maybe the gauge or wiring is bad
Old Nov 16, 2011 | 05:37 PM
SnuffthePunkz's Avatar
SnuffthePunkz
Drop tank, remove it, clean it up thoroughly, and put it in a bucket of water and see what it does. If it adjusts on it's own, might work, if not replace it.
EDIT: Remove all the water thoroughly after, and let it dry before re-installing it
Old Nov 16, 2011 | 06:49 PM
IllRespect's Avatar
IllRespect
Where would someone find a float? Do you have to replace the entire unit? My front tank doesn't register, but still works.
Old Nov 16, 2011 | 08:23 PM
starmilt's Avatar
starmilt
As far as I know you have to replace the whole unit.
Old Nov 16, 2011 | 08:38 PM
IllRespect's Avatar
IllRespect
That is what I am afraid of. I haven't been able to find one for diesels, I have found lots for the gassers. Is there away to modify one to work for these trucks?
Old Nov 16, 2011 | 09:08 PM
Marianna2003's Avatar
Marianna2003
I think the only difference between gasser & diesel sending units is the actual pickup. Everything else should be the same. I worked for AC Spark Plug when they were making the GM units. The higher viscosity of diesel dictated a change in the strainer.
Old Nov 17, 2011 | 04:18 AM
86f250XLT-4x4
I know the float moves up and down freely like it is supposed too the tank and float came from my parts truck I had to switch tanks because the scrap yard drilled a hole in the other tank
ThatFordGirl
Oct 28, 2016 11:49 AM
martinraz
Sep 1, 2016 01:48 PM
KsCop
Mar 20, 2014 02:49 PM
JoeVR5
Jul 18, 2010 01:07 AM
Craze
Jun 9, 2005 06:44 PM
