Sponsored by: Real Truck
Interior Trailer Lights
Old Nov 16, 2011 | 02:49 PM
tim432's Avatar
tim432
I want to be able to turn on my interior trailer lights without having to turn the ignition to the on position. Has anyone done this?
Old Nov 16, 2011 | 03:02 PM
1973Ford2004's Avatar
1973Ford2004
I've thought of it myself, but haven't done it. I was thinking of hooking up a couple of separate lights and running off a marine battery and tying it into my trailer brake battery for charging. Or maybe just switching out the trailer brake battery for a bigger one. Seems it would be easier than running a wire all the way from the truck.
Old Nov 16, 2011 | 03:59 PM
BillyBob69's Avatar
BillyBob69
You have the right idea. Trace the main power wire from the switch for the interior lights, and connect that to the trailer battery. If you don't have a trailer battery, then either get one or....you can run an additional 12V wire through the trailer connector. Not many pepole have the center pin on a 7pin connecter used. You can just supply constant power through that one. But keep in mind, that point on the truck side of the connector will always have power and will start building up corrosion on it. Just something to keep in mind.
Old Nov 16, 2011 | 04:09 PM
rs4-380's Avatar
rs4-380
if you are going to do that, please at least run it through a relay. THe interior light switch wiring is not up to the task of flowing enough current to charge a dead battery (which is what will happen it you hook a dead trailer battery up to a constant on source from the truck).
Old Nov 16, 2011 | 04:17 PM
BillyBob69's Avatar
BillyBob69
I actually meant to wire it to constant 12 from the truck when plugged in. This will eliminate the need to have a trailer battery. However....In case of a dead trailer battery..yes...you need a relay if charging a trailer battery from the truck....which these trucks already have set in place.
Old Nov 16, 2011 | 04:19 PM
tim432's Avatar
tim432
So the trailer brake battery, it is indeed charged from the truck? Think I will also replace the interior dome lights with LED's to conserve power. Thanks!
Old Nov 16, 2011 | 05:58 PM
RV_Tech's Avatar
RV_Tech
If you do not have a trailer battery, you do not have a functioning independent braking system in the event of an emergency requiring a break-away. It really does happen.
Steve
Old Nov 17, 2011 | 05:07 AM
1973Ford2004
Thanks Tim432 for posting the question and thanks guys for the answers, got me thinking a little more about this project now, haha.
Skral
Jun 1, 2019 03:47 PM
Keith Mathewson
Jun 5, 2018 05:59 PM
Simoncx
May 10, 2009 08:46 AM
RussellF
All Things Towing
22
Apr 1, 2007 10:23 PM
dogger
Nov 20, 2006 11:13 AM
