Steering column starting/run wiring
Old Nov 16, 2011 | 02:01 PM
Madathlon's Avatar
Madathlon
I have this 1985 F-250 with the 6.9 in it. I have replaced the starting/run thing a few time, (Just cant remember the name off the top of my head) it keeps going bad in that after a few months it will no longer let the engine run. It will start and as soon as you release the key it dies, If I hold the rod just right it will keep running. what I like to do is add a a manual run switch by-passing the OEM circuit. But I dont know what wire in the bundle is the correct one t tap into.
It would be greatly helpful if someone has done this before and what wire to tap into.
Old Nov 16, 2011 | 04:53 PM
tjc transport's Avatar
tjc transport
i ain't rite
what are you changing, the key cylinder, or the ignition switch under the column?
Old Nov 16, 2011 | 05:25 PM
Madathlon's Avatar
Madathlon
I am talking about the ignition switch under the Column part, KS would be a easy swap, but Im tired of yanking the column to fix the ignition switch. I have replaced it 4 time in the last year and even had ford do it once. Im tired of fixing this one part and just need to find the run circuit to add a by-pass.
1bigjoe
19
Jan 29, 2012 10:12 AM
dcberg
Feb 26, 2010 07:31 PM
oarhead61
Apr 15, 2006 09:15 PM
JayB1
Electrical Systems/Wiring
Oct 25, 2005 06:45 PM
wildjon300ci
Apr 1, 2003 07:06 PM
