New Rag Joint
Old Nov 16, 2011 | 08:40 AM
likeagoodbook's Avatar
likeagoodbook
New Rag Joint
I installed a new steering rag joint and it seems to work but the whole thing just doesn't seem quite right to me and I can't remember what it looked like before I started, please take a look at this picture and let me know if anything doesn't look correct. Thanks ahead of time.
Old Nov 16, 2011 | 09:15 AM
huckdeuceman's Avatar
huckdeuceman
It looks like one of the ears? if that's what it's called is broke off on the plate the rag
joint bolts too? where it's fleared up on two sides they should look the same! at least that's what my 65 looks like!, turn the steering wheel and see what the otherside looks like, that will give you a better idea..I could be wrong depending on what year truck you have?
Old Nov 16, 2011 | 09:55 AM
likeagoodbook
Her's the other side, I don't think anything is broken but I might be missing something, for some reason I couldn't find a good exploded view of this connection in the repair manual. My old steering box was trashed and I pulled one from a 66 out of the junk yard and installed in my 65, I know there's a slight difference between the two but I don't think that's my issue.
Old Nov 16, 2011 | 11:08 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Whole thing looks out of alignment. Get that column bearing retainer in properly for one thing.
Old Nov 16, 2011 | 12:41 PM
camperspecial65's Avatar
camperspecial65
Actually, in the 2nd pic you can see the lower bearing retainer all cattywampus at the end of the mast jacket...you need most likely at least a lower column bearing and sleeve...readily available and inexpensive...to replace it requires removal of column and teardown of it...
If you are having turn signal or horn issues...this would be the time to replace the switch and wiring at the same time.
As to the rag joint...in 65-66 F100-250 trucks there were 2 used...the guide pin was a different diameter between the two and I suspect that would also affect the steering shaft itself too...if you 'rebuilt' your original rag joint all should be well...unless the column isnt original to the truck.
Post the last 6 of your VIN as there was a specific number when the rag joints became different...the pin should fit semi close tolerance into the bottom of the steering shaft cutout.
The column bearings being bad will also make it alot harder to steer the truck as the angles are always on the move...which they shouldnt be.
- cs65
Old Nov 16, 2011 | 01:31 PM
likeagoodbook
Thanks guys, neither my horn or turn signals work so I was needing to get into the column anyway, the steering column seems original to the truck but this probably explains some of the continued tough steering and why the column seems to want to pull away from the rag joint excessively, looks like I need to get a steering wheel puller and some new parts!
Old Nov 16, 2011 | 01:40 PM
camperspecial65
yup...thats the same as mine...dead horn and a toast rag joint...I replaced mine a couple of years ago...what a difference!!!!
- cs65
Old Nov 16, 2011 | 05:32 PM
kilich's Avatar
kilich
Heres a picture of my dads on his truck.
Old Nov 17, 2011 | 01:39 AM
garbz2's Avatar
garbz2
65 66 use the same small diameter pins.
The one you have has small and large pin common with later units and the ones in the help section. To use this joint you need to modify the flange to clear the large pin. A bit of grinding will provide sufficient clearance.
It also appears that the lower column bearing has damage and will need to be rebuilt.
Garbz
Old Nov 17, 2011 | 08:43 AM
huckdeuceman
The post #8 is what my joint looks like on my 65! didn't know they had different ones?
Learn something new everytime I read or post!!..That's a good thing!
Zachs66
Arizona Chapter
13
Feb 19, 2015 08:48 PM
bill2298
17
Sep 25, 2014 09:15 AM
Jimmyfoxx
Apr 11, 2013 08:00 PM
Fordrat
Sep 13, 2012 04:00 PM
DRanchero
Aug 9, 2004 10:45 PM
