Grinding while in third gear
Old Nov 15, 2011 | 11:23 PM
Twete77's Avatar
Twete77
Hey all, this is my first post to the forums . I just recently bought a 79 F250 Ranger XLT with a 400M and a 4spd which I believe is an NP435 mated to a 205 transfer case. Anyways, I have noticed the truck makes a grinding sound (and feeling) while in third gear and third gear alone. I don't believe it to be a problem with the syncro because it shifts just fine but once in gear it makes a slight grinding sound and feels rough, almost 'sandy' (for lack of a better word). Anybody have some sorta idea what might be up? Possible missing gear tooth? Bad bearing? Or something completely different? Any advice would be great!
Old Nov 18, 2011 | 11:33 PM
85e150's Avatar
85e150
If it's a a bearing, you should get it all the time.
Check your floor--you should have a removable panel to get to the trans. Pop the top of that trans and you'll have your answer methinks.
You are not alone. Check post 6 for links regarding removal of the shifter:
https://www.ford-trucks.com/forums/1...cond-gear.html
Old Nov 21, 2011 | 12:46 PM
Twete77's Avatar
Twete77
Thanks for the info! I bought a rebuild kit for it anyways just because I figure I might as well go through everything if I'm gonna break the transmission open. The more and more I think about it I'm kind of expecting to see a missing tooth on third but we'll see. When removing the cover of the transmission from inside the vehicle am I going to need to drain any fluid first? Or is it ok to just pop the lid off? I appologize if these questions have been asked in other threads but I really appreciate the advice!
Old Nov 21, 2011 | 02:02 PM
85e150's Avatar
85e150
I would think you could pull it without draining the fluid. You may be able to see better without the fluid.
Be sure no dirt, debris or children fall in....
TheHouse
Aug 31, 2007 10:46 PM
Fiferian
1983 - 2012 Ranger & B-Series
Jun 11, 2004 09:41 AM
fourplay ford
Dec 4, 2003 10:09 PM
trojanman25
Jun 21, 2003 01:03 PM
mike90sc
Bronco II
Mar 23, 2002 06:43 PM
