Noob needs help...please!
Old Nov 15, 2011 | 09:47 PM
ICR's Avatar
ICR
Question Noob needs help...please!
I have a 1969 F100 with an inline 6 (302?))... I also have a 351 Cobra Jet that my awesome dad has given to me to put in the truck. Will the transmissions work together? Is there anything weird I'm going to encounter when swapping these 2 engines that you guys could give me the heads up on? Thanks in advance!
Old Nov 15, 2011 | 10:51 PM
69 F100 Cali's Avatar
69 F100 Cali
I don't know if the transmission will transfer over but i have a 300 inline six which is probably what you have either a 300 or 240 which are virtually the same but the stroke i think is a little bit more on the 300 along with more displacement, I believe. But I'm interested in this answer too haha.
Old Nov 16, 2011 | 11:55 AM
DPhillips's Avatar
DPhillips
If it's a 351 Windsor, the bell housing and trans should work. 351 Clevelands and 351M motors have different bell housing patterns.
Old Nov 16, 2011 | 07:17 PM
ICR's Avatar
ICR
Awww man! I am fairly certain it's a Cleveland... I'll have to ask my dad to be sure. I guess I'll post in here when we figure it out!? So much for hoping for easy.
Old Nov 17, 2011 | 03:38 AM
jowilker's Avatar
jowilker
Are you sure about the bell on the Cleveland, I'm thinking it used the same bolt pattern as the Windsor & 6 banger. I could be wrong but was the C sold as a Cobra Jet or was that 428 & 429 engines.
John
Old Nov 17, 2011 | 11:00 AM
mikeys71sportcustum's Avatar
mikeys71sportcustum
The Cleveland was sold as a cj motor. the torino had them in 72.
Old Nov 17, 2011 | 11:37 AM
limegoldf100's Avatar
limegoldf100
Cleveland has same bolt pattern as 240/300/302/351W. 351M is same as 400/429/460.
Old Dec 20, 2011 | 09:16 PM
ICR's Avatar
ICR
Alright fellas, sorry to pull the girl card here some more but can ya give me pointers on changing brakes from drum to disc in this old pick em up truck? I've heard something about spindles from another year truck, like a 73 or a 79 or something??
Old Dec 20, 2011 | 09:28 PM
HIO Silver's Avatar
HIO Silver
Read this tech article on Fordification: Installing Disc Brakes on Your 2WD Pickup - Pt. 1 - FORDification.com
I'm using 78 discs and RAs on DJM beams (just arrived!!!) and booster and MC from a 75.
Old Dec 21, 2011 | 06:08 AM
jowilker's Avatar
jowilker
Find & buy a 73-79 donor truck that has the engine & tranny type that want your truck to end up with. It will have all the parts needed for your upgrade. Later when you need replacement parts just refer to ** year and walk away. Lift the front wheel off the ground and test for king pin wear. Keep the front end well greased, king pin wear will be very little.
John
Old Dec 26, 2011 | 11:53 AM
ICR's Avatar
ICR
thank you guys....
Old Dec 26, 2011 | 12:06 PM
Phreaq's Avatar
Phreaq
John
Lift one wheel or both? I'm fairly sure mine are worn out as my trucks second life was a ranch truck pulling tractor equipment for around 20 years.
Old Dec 26, 2011 | 04:38 PM
jowilker's Avatar
jowilker
Bud, Using the truck doesn't wear king pins as long as they are kept greased. It is the lack of grease that allows for accelerated wear.
It won't take but a moment longer to check both sides. Place a hand and 12 & 6 oclock while pulling up & out from the bottom. 1/8" or less movement is not bad, more I might keep looking.
John
F-250 restorer
Jun 28, 2014 08:09 AM
vaughn1977
13
Feb 19, 2007 10:36 AM
96sherm
20
Aug 31, 2006 04:15 PM
thecowboy
Engine Swaps
Aug 18, 2004 10:22 PM
