What is normal for ICP?
Old Nov 15, 2011 | 07:39 PM
wgcdc's Avatar
wgcdc
I have researched this subject, but so far I haven't been able to find a clear answer.
What is normal ICP range (psi) at idle, normal operating and heavy load? I can monitor this on my DashDaq.
I can't monitor IPR % which I assume is important.
Thank you
Old Nov 15, 2011 | 08:00 PM
bismic's Avatar
bismic
My DashDAQ monitors the IPR duty cycle (%).
Your readings may be in kPa or MPa, so you may have to convert.
http://www.onlineconversion.com/pressure.htm
ICP at idle is just over 500 psig (actually 500-580).
can't recall normal operating (ie highway at 70 mph), but I will check tomorrow.
Heavy acceleration can be 3000 psig+
Old Nov 15, 2011 | 08:21 PM
wgcdc's Avatar
wgcdc
Thank you Bismic.
Do you have the enhanced Ford driver for your DashDaq? I can't find IPR duty cycle on mine, but I'll check again. I don't have the enhanced Ford drivers.
I am seeing around 600 psi at idle, 1,500 - 2,000 psi at highway speeds and 3,000 psi at heavy throttle/high RPM. Am I correct to assume that between ICP and IPR duty cycle we can determine if we have high pressure oil leaks?
I also saw on DashDaq's forums where you were trying to monitor FICM voltage with your DashDaq. Were you able to do this?
Old Nov 15, 2011 | 08:32 PM
BLADE35's Avatar
BLADE35
yes Between the 2 ICP & IPR% you can determine if you have a HPO leak
Old Nov 15, 2011 | 08:35 PM
bismic's Avatar
bismic
I do have the Ford Enhanced bundle.
There has not been a way to get FICM voltage w/ the DashDAQ - at least not that I know about. That is my one dissapointment w/ it!
bizzelj
Nov 28, 2023 10:18 AM
Last_Stroke
Oct 5, 2016 06:31 PM
gdool
31
Dec 16, 2014 10:39 AM
KRDiesel
Apr 21, 2013 07:39 PM
aocabrown
Feb 11, 2008 04:15 PM
