terrible valve knock
Old Nov 15, 2011 | 07:14 PM
joekacker's Avatar
joekacker
I lost all spark about a month ago. I changed the icm today. had to pull the disty. made 3 marks, one on the disty to block, one where the rotor was pointing, and the other on the manifold from the back of the cap. , So I did this all today this hour, got it all back in.. truck fired righht up. But now its blowing an assload of rich smeliing smoke and has severe valve knock, liek theres no oil in the rig??? I know I could be off a degree or so, Would bad timing cause this to happen? Ive seen the smoke but never the knock. and the truck was running fine when it broke down..
302efi 91 f150
Old Nov 15, 2011 | 07:47 PM
73FOMO's Avatar
73FOMO
Pull the spout and set the distributor at 10 degrees with spout removed with a timing light. To me sounds like way too much advance. If you don't have timing light, keep backing off dist. turning counter clockwise until things smooth out, but you really need to check and set as described above.
Old Nov 15, 2011 | 07:52 PM
joekacker's Avatar
joekacker
thanks . Ill have to dig out the old craftsman light lol... so wierd it went right back in the way it cameout, Thanks for the response bud. Im still new to the dyi mechanics, so im learning more everyday.
Old Nov 15, 2011 | 10:48 PM
94BigRed's Avatar
94BigRed
What's this spout I keep seeing pop up? I might have to put in and time a new dist and this is new to me and I'd like to be able to time at home.
Old Nov 16, 2011 | 04:38 AM
lew52's Avatar
lew52
302efi 91 f150
Whats your oil pressure ? you could have a problem with the oil pump shaft that goes into the bottom of the distributor ...Lew
Old Nov 16, 2011 | 04:44 AM
lew52's Avatar
lew52
....The spout is a jumper that needs to be removed to set the base timing , by removing the spout it disables the computer advance , it should by the left fender below the master cylinder , its just a plug that pulls out of the wiring harness....Lew
Old Nov 16, 2011 | 05:35 PM
rla2005's Avatar
rla2005
Ford Fuel Injection » Setting the timing
Old Nov 18, 2011 | 04:22 PM
73FOMO's Avatar
73FOMO
Yes...this is a good point as well the bottom of the distributor engages the oil pump shaft....but that wouldn't explain the rich smelling smoke, as in the spark is occuring at the wrong time and leaving a bunch of fuel in the cylinders.
Old Nov 18, 2011 | 04:51 PM
Slip ford man's Avatar
Slip ford man
What does that mean?...it always would smoke in the past?
I would put a vacuum gauge on her, read these over.
http://www.classictruckshop.com/club...vac/vacuum.pdf ...and
Vacuum Engine Timing | MILEPOSTS Garage (Tech Tips)
JamesJ4
Apr 12, 2025 10:22 PM
RocketmanVT
Dec 30, 2012 05:04 PM
drjoe171
Sep 18, 2011 07:24 PM
cowboyup11
Feb 2, 2009 02:26 PM
OrionsIce
1983 - 2012 Ranger & B-Series
Jan 5, 2003 11:46 AM
