V codes verses X codes
Old Nov 18, 2011 | 04:33 PM
LivingLarge's Avatar
LivingLarge
Originally Posted by locknload223
Ya know, now that I look at mine and others, I wonder if mine is a 2" hanger? It kind of looks like it. I'll do some measuring when I get home. The PO said it was a 4" and it sounded right because it had 315s on 10" rims.
NOW, I wonder...
Mike, is it possible that you have hangers in the rear?
Or like you mentioned 2 inch hangers?
I have the same F350 blocks you have and the same V's, if i raised front 4 inches i would sit 2inches higher in the front. Now with the RAS i have gained 1 inch but still would sit 1 inch higher in the front with 4 inch hanger.
Can i also bother you to measure from center of hub to bottom of fender both front and rear.
Picked you cause your somebody!!
I'm in no hurry, so no pressure!
Old Nov 20, 2011 | 05:40 PM
locknload223's Avatar
locknload223
My shackles are stock but I do have add a leafs in the rear springs as part of the hanger kit. The add a leafs usually yield around 1 1/2" of lift. I think most hanger kits would come with an add a leaf or block. Generally the rear get's half the lift of the front to maintain a level stance.
Center hub to fenderwell,
My front measurement is driver-28".
Rear is driver-28 3/4".
Front hanger measures 6 1/4" from the top of the hanger to the center of the spring bolt. No idea what the stock perch measures. Maybe some one with a known 4" or 2" hanger can measure theirs?
Old Nov 20, 2011 | 06:00 PM
LivingLarge
Mike, first thank you for taking time to do this!
Your front is 3 inches higher than mine.
Your rear is 2.5 inches higher than mine.
So now I know there is no way the 315's will fit with just X codes.
I will start looking at hanger kits etc.
Not going to X codes.
Thanks again,
Michael
Old Nov 20, 2011 | 06:12 PM
locknload223
Thanks again,
Michael
You bet bud, keep us 'posted'.
Old Nov 20, 2011 | 07:50 PM
wpnaes's Avatar
wpnaes
Sean, Thanks for the pics. The 315's look great! What do you have in the rear, as far as lift?
Michael
The rear is completely stock. 315's work fine, even stuffed.
rickdavis81
Sep 24, 2015 01:26 PM
camo77566
May 24, 2015 05:31 PM
mark1313
Apr 30, 2015 05:07 AM
bassman94
Nov 17, 2012 08:21 PM
Helidriver
Aug 4, 2010 01:57 PM
