I have 4" all spring lift and 315's rub on 16x10" rims. I can't see how anyone expects to run 315's without rubbing on 2-3" of lift. My stock F250 ran 315's on 8" rims and rubbed. I went to 4" blocks and a Edge mini spring pack for an additional 1.5" of lift and barely clear enough not to rub. 305's are the biggest you can run, safely.
I've been running a 3" shackle kit up front, and 315s all day long.
... and it's a PSD (heavier)
However, on the stock wheel... it'll rub heavily on the leaf spring at full lock. And even with a 8.5" wheel, it rubs, and does so a tad bit on the inner fender well when I'm at full lock and the suspension cycles a tad bit.
So sure it rubs, but nothing like it's tearing inner wheel wells apart. I ended up using large zip ties to pull the wheel well away from the tire, and it's worked great for a long time.
Agree'd with the rest, I think you're going to need more than X codes to run 315s. I was rubbing on hard lock with my 4" hanger and stock springs. Granted they were pretty worn out but you get the idea. Add a small 2" hanger to X codes, or save some coin and add a 4" to your V codes. Are they new spring packs? Hate to see you start all over money wise.
Mike, when you get the chance can you post a pic of your Hanger and lift size. If i recall, you do not know the brand?
If i go the hanger way, i would probably keep the V-codes.
Ya know, now that I look at mine and others, I wonder if mine is a 2" hanger? It kind of looks like it. I'll do some measuring when I get home. The PO said it was a 4" and it sounded right because it had 315s on 10" rims.
