Cruise Control
Old Nov 15, 2011 | 05:18 PM
palmer77crew's Avatar
palmer77crew
Cruise Control
Went Junkyarding this weekend and couldnt help myself. i ended up pulling the cruise control off of a 1979 f350 ranger camper special with an automatic. my question is will this work with my 1977 f250 crew cab with a 4 speed. i got everything from it but the instrument panel was already out of it. now im worried because i was looking around today and keep hearing about upper and lower cruise control speedometer cable. any help or advice appreciated.
Old Nov 15, 2011 | 07:35 PM
Stinky7-11's Avatar
Stinky7-11
I don't really like to be negative but after all i just went through to get my fatory installed cruise working i would put it all in a box and ship it to me! No really, if you have everything and the electrical background it will be a challenge. That's if it would even work with the standard trans. Did you get the steering wheel, horn pad and the directional switch? It's also wired into the brake system and the device that's in between the upper and lower speedo cables! I'll be looking for that box! If i were you i would direct my energy,time and cash to something that would be moe useful, i fixed mine only because it was factory installed. Hope that helped.
Tony
AKA Stinky
Old Nov 16, 2011 | 01:52 PM
palmer77crew
yeah i got all the horn and directional switches. i talked to a guy who did the same thing. he got a conversion for the speedo said the rest is not to difficult. thanks
Ryan
Old Nov 16, 2011 | 04:42 PM
camperspecial65's Avatar
camperspecial65
What engine is in the donor and which engine is in yours ?? Factory installation setup or dealer installed ?
- cs65
Old Nov 16, 2011 | 06:00 PM
palmer77crew
The donor English was a 460 and I have a 400. I believe it was factory with being in harnessand the box and connections had Ford numbers. How can you tell.
Ryan
Old Nov 16, 2011 | 06:51 PM
camperspecial65
Factory= horn pad buttons, dealer install...mounted on LH side of column by turn signal arm
- cs65
Old Nov 16, 2011 | 09:59 PM
palmer77crew
It was a factory unit.
Old Nov 16, 2011 | 11:38 PM
lostinfords's Avatar
lostinfords
you need that sensor/module?? that the lower speedo cable screws into to monitor/sense the speed and the shorter speedo cable from there to the instrument cluster, fear not...I have been told that some/most cars utilize the same parts..nice score good luck w/ the set up...I will be watching for the results
hijack/sidenote: post up a pic of the truck I am re-doing the same crew, just that my 4wd 77 crew had the frame stretched for the 8' bed
1997Aerostar
Aerostar
Apr 30, 2017 08:41 PM
mcarb80682
Apr 27, 2017 10:19 PM
BigRed1967
Dec 29, 2009 10:23 AM
hilgerbeast
Jul 21, 2009 01:46 PM
