Instead of fixing I broke 2 more thing
Old 04-24-2017, 02:33 PM
mcarb80682's Avatar
mcarb80682
mcarb80682 is offline
Hello,
My speedometer stopped working yesterday after i replaced the 2 cruise control buttons on the steering wheel. When i connected the the battery the horn started blasting and I went over tap the horn then it stopped. Then i noticed that the horn did not work anymore. I put back the original cruise control buttons and still did not work .So know instead of fixing the cruise control buttons, I broke the horn and the speedometer while the cruise control is still broken. I checked the fuses and they all are good. What can it be ?
Old 04-24-2017, 03:11 PM
CharlyG's Avatar
CharlyG
CharlyG is offline
Sounds like Murphy is in the neighborhood for a visit...
Old 04-24-2017, 09:25 PM
mcarb80682's Avatar
mcarb80682
yep, maybe i should ask how can i fix my speedometer. what does the steering wheel have to do with it
Old 04-26-2017, 09:20 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Old 04-26-2017, 09:30 AM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
I know the feeling. I went over my battery connections amd a couple grounds to clean things up a little and now my extra fuse panel is loosing power periodically. Tracking down electrical problems is a never ending project.
Old 04-26-2017, 12:58 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Vinny G-the EX man is offline
Similar situation happened to me with my speedometer, however I lost my gauges as well when we were on a road trip to Virginia, battery went dead and needed AAA to give me a jump. When we hit the road I had no spedo, gas gauge ect. Drove home with out them using my Garmin as spedo. My mechanic told me to disconnect the battery for a few minutes and the reconnect it, it WORKED. You might not have done anything during your repair it might just be that system needs a reset. Its worth a try. Good luck
Old 04-27-2017, 10:19 PM
mcarb80682's Avatar
mcarb80682
Thanks , to all the replies, I disconnected the battery checked fuses again found one the horn, replaced connected battery now speedometer works, I thank god. horn does not work but hey speedometer work again
86f150step
09-23-2013 07:21 PM
blindfury37
1999 to 2016 Super Duty
05-31-2009 05:27 PM
CJay
10-11-2007 10:28 PM
Stangfire
1997 - 2003 F150
03-20-2005 03:58 PM
ranger429
05-27-2004 09:25 PM
Quick Reply: Instead of fixing I broke 2 more thing
