cb question
Old Nov 15, 2011 | 03:39 PM
bigbubba87's Avatar
bigbubba87
cb question
I put my cb in my new truck and when I talk my voice comes out through my subs. I have a uniden cb and a heavy duty jensen stereo from john deere. It does not play on my speakers in the doors just my subs. Had the same setup in my other truck and never had it do this. Any ideas?
Old Nov 15, 2011 | 06:30 PM
fordtruck661's Avatar
fordtruck661
Just get rid of the subs....lol. Do you have your CB hooked up to your stereo? or are the power wires next to one another on the battery?
Old Nov 15, 2011 | 06:42 PM
snakedoc's Avatar
snakedoc
your wires to the sub may the same wave length as the CB frequency and is working like an antenna. that or you have some feed back problem.
Old Nov 15, 2011 | 06:56 PM
bigbubba87's Avatar
bigbubba87
Il have to check how I wired it. In my other truck cb was wired into the.fuse panel under the dash. And ground was run to the factory ground point the is on the right when you remove the kick panel under the steering wheel.
Old Nov 15, 2011 | 07:00 PM
nlemerise's Avatar
nlemerise
I think we have a winner...shield the lines to the sub...
Old Nov 15, 2011 | 10:02 PM
johnarahill's Avatar
johnarahill
If you have an amp you may need to shield it as well.
Old Nov 15, 2011 | 10:07 PM
baddad457's Avatar
baddad457
Yea, that's what's called "talk back" I have it done to all my CB's. Just plain sounds better when you can hear what you're putting out, instead of "dead air"
Old Nov 15, 2011 | 11:39 PM
Smokiesman's Avatar
Smokiesman
10-4 Good Buddy!! see ya on the flipside!
Smokie
KhanTyranitar
Aerostar
54
May 31, 2020 11:33 AM
Thewiller
Sep 27, 2012 07:00 PM
Hometown Pride
Apr 23, 2009 10:04 PM
kilog55
Aug 20, 2006 03:29 PM
