shock mount
Old Nov 15, 2011 | 05:55 PM
Cody_302's Avatar
Cody_302
Originally Posted by turbohunter
BTW
Nice lookin truck.
Thanks!
Old Nov 15, 2011 | 07:12 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
If the sleeve comes off it will fit right? If so I'd start with a 3" cutting wheel on a high speed. Cut it lengthwise, You won't be able able to cut it all because if the bolt head, but you will get about half cut, and can finish with a sharp cold chisel. Should come off.
Old Nov 15, 2011 | 07:42 PM
Cody_302's Avatar
Cody_302
yes if i could get the old sleeve off it would work but i think im going to try the bushings to avoid risk of damaging the stud.
Old Nov 16, 2011 | 02:43 PM
Cody_302's Avatar
Cody_302
went to go order the bushings today and the guy said that the inner diameter was the same as the ones that came with the shocks...
Old Nov 16, 2011 | 04:30 PM
turbohunter's Avatar
turbohunter
It's not. I ran into the same thing.
They're looking at a parts book.
For some reason the rubber sent with these shocks is to small. The poly is the right size. At least mine was. Maybe a part number is screwed up.
I'm going to call BG tomorrow morning and yak about it. I'll also ask them who builds their shocks then call the shock maker to see what the scoop is.
I'm really curious as to what's up also.
I'll get back with you tomorrow.
Old Nov 16, 2011 | 04:44 PM
Cody_302's Avatar
Cody_302
i appreciate it. this has really turned into a problem. you bought your shocks from BG that comes with a 1 piece black bushing you have to press in?
im going to try an get some pictures around.
Old Nov 16, 2011 | 04:57 PM
turbohunter
Yes exactly.
We'll get it figured out.
Old Nov 16, 2011 | 05:03 PM
Cody_302's Avatar
Cody_302
ok here is the new shocks from bronco graveyard...
old on top new on bottom...
old on left new on right...
old bushing inner diameter is 3/4 inch...
new bushing inner diameter in 5/8 inch...
Old Nov 16, 2011 | 05:18 PM
turbohunter
Here is my post on the same subject.
https://www.ford-trucks.com/forums/1...-did-it-6.html
Old Nov 16, 2011 | 05:19 PM
SwOkcOffRoader
I've cut tons if those off. A steady hand, a good high speed cutoff wheel, chisel and hammer, and your golden. Or buy more parts.
Old Nov 16, 2011 | 05:23 PM
turbohunter
If I was going to a dual shock set up (which I will later) I wouldn't have a problem cutting it.
For now though I want it to be stockISH.
Just fries my nads that there is no research material/listings for it.
Old Nov 16, 2011 | 05:25 PM
Cody_302's Avatar
Cody_302
i remember stumbling across this some time ago. what makes me remember is the stack of tags lol.
Old Nov 16, 2011 | 05:32 PM
  #28
turbohunter
Yup, that was a crack up.
Come to think of it, I just got a full set of shop manuals for it, so I'll check those also and get back too you. (at work now)
Old Nov 16, 2011 | 05:38 PM
  #29
Cody_302's Avatar
Cody_302
my truck came with a set also. volume 1-4. haven't even thought about checking them out. kinda forgot i had them.
Old Nov 16, 2011 | 06:08 PM
  #30
Cody_302's Avatar
Cody_302
here is a link to exactly what i need (ID 3/4)
19918 Shock Mount Bushings - Hourglass Large Halves - 3/4 Inch ID
cant believe BG cant specify what there selling.
