Sponsored by: Real Truck
4x4 problems
Old Nov 15, 2011 | 01:35 AM
TWF350SD's Avatar
TWF350SD
4x4 problems
hey so i just bought a 2008 F-350SD lariat crew w/ 4" skyjacker lift, anyways we had our first snowfall today and i went to switch in to 4WD on the dash switch, the light turned on (4x4 high) but rear wheels sill spun out and nothing engaged. Before i pay money to fix anything does anyone know what this problem may be? thanks
Old Nov 15, 2011 | 04:24 AM
mike68gt's Avatar
mike68gt
Not sure if you have the same system as my 04 but my vacuum line cracked going to the hubs so it wouldnt engage. Can you hear the transfer case motor shifting?
Old Nov 15, 2011 | 09:20 AM
senix's Avatar
senix
If your heat turned to defrost then you have a vacumn leak.
You can still go around to the hubs and turn them to lock them in.
Old Nov 15, 2011 | 12:33 PM
TWF350SD's Avatar
TWF350SD
There's no shift thud or sound what so ever from the transfer case just the light.
Old Nov 15, 2011 | 01:02 PM
senix's Avatar
senix
Does you heating and ac go to defrost?
Old Nov 15, 2011 | 01:07 PM
TWF350SD's Avatar
TWF350SD
Not to sure haven't noticed its always on anyways because of the cold. Would it just come on defrost no matter what I switch it to?
Old Nov 15, 2011 | 01:27 PM
senix's Avatar
senix
Put it to the floor and then switch the 4x4 on and if it immediately goes to defrost then your vacumn leak is somewhere from the solienod under the hood to the front hubs.
So then you can start at the hubs and check the vacumn lines. Work your way backwards.
Old Nov 15, 2011 | 01:29 PM
TWF350SD's Avatar
TWF350SD
Awsome ill have a look thanks
Tyler Yost
Mar 5, 2018 09:12 PM
BigBlackF-250
Mar 17, 2015 08:25 AM
Big Sky
Sep 23, 2014 07:23 PM
bonsiguy
Jan 12, 2007 08:00 AM
