King's E-fuel
Old Dec 2, 2011 | 08:48 PM
  #31
Brown Falcon's Avatar
Brown Falcon
Yeah, I still want to know what the p/n is and where you got the banjo adapter...
Old Dec 3, 2011 | 05:52 AM
  #32
King7765's Avatar
King7765
Hydraulic Warehouse - 6404 Series - Female O-Ring Boss (ORB) x Male Pipe (NPTF) Adapter
6404-12-08 is the one you want.
Your probably not gonna find it cheaper anywhere else. Most stores wanted 12-18 for this piece. Some were higher. Couldn't even get my buddies at my local hydraulic shop to order it for me that cheap.
Old Dec 3, 2011 | 11:30 AM
  #33
Brown Falcon
Awesome! Thanks King!
Old Dec 3, 2011 | 11:35 AM
  #34
redman84's Avatar
redman84
Thanks dude!
Old Dec 3, 2011 | 05:45 PM
  #35
redman84's Avatar
redman84
So as if I haven't been needy enough...Have you had time to get any pics or description of the wiring together?
Old Dec 4, 2011 | 08:00 AM
  #36
King7765's Avatar
King7765
I found my wiring schematic, but I also found that my 3-in-one printer is not scanning documents now, nor is the freakin wi-fi working.
So my girlfriend is trying to find the receipt to see if it's under warranty.
Also, this past week has been NUTS at work.
Old Sep 17, 2013 | 07:20 PM
  #37
King7765's Avatar
King7765
I'm ashamed I never put together a parts list and price list together for this thread or posted pics of the wiring. Someday I'll dig up the receipts and wiring diagrams. I saved ALL of it.
The E-fuel setup has worked perfectly since it was installed. Only changed filters.
Those STOCK lines from the banjo fitting to the rear of the heads are plenty big. I dyno'ed almost 400hp.
( I want more, but this is a work truck)
Old Sep 18, 2013 | 07:03 AM
  #38
OldWoodsDiesel's Avatar
OldWoodsDiesel
King - thanks for updating this thread - your original one was pre-me on FTE and i'd probably have never come across it. i'm eyeing up e-fuel someday soon, hopefully and your setup looks pretty straightforward and relatively low cost.
in the absence of a parts list and diagrams, I have a few questions that you might know off the top of your head:
- where did that prefilter and base come from? the post filter is a standard napa filter and base, but I haven't seen that pre-one before.
- what is the order of pumps/filters/etc? from what I can follow of hoses in one of your pics, it goes: fuel selector valve - pump1 - pre-filter - pump2 - post filter - engine (banjo adaptor) - regulator - fuel selector valve (return) Is this right, or do I have something mixed up?
- pump fuses - did you add a fuses and a relay to the under-hood box, or just run an in-line fuse somewhere?
and again - nice work and glad its still working like day 1.
Old Sep 18, 2013 | 08:35 AM
  #39
King7765's Avatar
King7765
The prefilter and base came together as a kit. It has a heater in the top also. I have the 150 micron filter #33169
I know you can order them as "assemblies" but here are some options.
Filter head: probably need 3/8" or 1/2" ports. STA30837 or STA33648
Stanadyne Fuel Manager Diesel Parts Selector
Filter alone: I see now you can order them in 3.6", 4.3" and 6" lenghts. I have the 3.6" 150 micron (it's a prefilter for the pumps) and I may order a longer one for a few extra bucks.
I also have the see through bowl #29899, but when I ordered my setup I didn't specify that I needed or wanted this. Maybe they offer it as an option now instead of standard equipment.
29899 Stanadyne KIT,FM100 SEE THRU B
They offer a heater for the top also. I don't know if I have the 100watt or 150 watt heater. They offer a heater for the side, buuuuut I don't see the point, the toploaded heater element was easy to put in. Real easy.
They sell assemblies. Some of the discriptions are non existent. I would call and tell them what you want and see if they sell it in a kit.
The fuel system goes as follows:
fuel selector valve to fuel manager prefilter with dual outlets to the inlets of the pumps (ran in parallel) then out as separate lines to two inlet ports on post filter head then out as one single line to engine.
fuel selector valve - prefilter - pumps - post filter - engine banjo - into heads - to "tight wad" regulator - back to fuel selector valve
I found a dual relay setup off a ford truck in the junkyard. May have came off a gas truck. It was right behind the main fuse panel under the hood, but had it's own mounting brackets and everything. For the pump fuses and heater fuse i tore apart a fuse panel in the junkyard and took out the fuse holder pieces INSIDE the fuse panel. It took for ever, but made for a OEM look under the hood. I have to check my glow-plugs this morning. I'll try to snap some pictures
Old Dec 22, 2013 | 08:00 PM
  #40
OldWoodsDiesel
Hey king, it's been a while since this thread was active, but here's a belated thanks for those links. I've got my engine on the stand finally and will be working my e-fuel setup soon. That banjo bolt adapter is def going to be part of my setup.
Gonna look into those filter set ups too. The heater in the filter is smart. I've never had fuel gel on me, but I'd rather not find out what it's like!
Also - anyone know what the stock hard line and fitting material(s) are? Stainless, plain steel, brass/copper?
ralphhood3
Feb 22, 2011 12:33 PM
66F100Again
Jul 3, 2009 12:44 PM
hillbillydeluxe4x4
Feb 24, 2008 03:30 PM
Goobzilla
Nov 13, 2004 03:14 AM
BlueOvalRage
Apr 27, 2003 11:39 PM
