I picked up an 89 f250 with a 521 ci stroker. It has a 4 speed trans behind it. All I really know right now is it has a comp cam, hooker headers, big Holley double pumper carb and the stroker kit. About what horse power level am I looking at?
What compression ratio? Which Comp cam? What heads are on it? Has any work been done to them? What intake manifold is on it? What size is the carb? We need much more information if you want anything close to an accurate answer.
That's the problem. I'm not quite sure. I don't think the old owner knows either. Its a 750 double pumper. The heads are cast, that's a given. I believe it had an aluminum intake on it but not sure of a part number. I'll have to clean it up and look for it.
I'll have to do some testing to see what al it had. I'll try to post cam specs when I figure out out I'll talk to the old owner and see what he knows but he seemed pretty clueless, that's probably why I got the whole truck for 500
[QUOTE=Diesel_Brad;11040612]I would 1st find out if it is even a 521[/QUOTE
To do that I'd have to tear it down to the bare block correct? Or is there a better way? I mean either way I bought a good parts truck. 500 bucks for a solid body and a 460 motor trans and t case. I can use the body for my other 89 pick up that's falling apart and the 460 trans and x case for my mud truck.
