460 stroked to 521. how many horse?
Old 11-15-2011, 12:19 PM
BRay09's Avatar
BRay09
BRay09 is offline
I picked up an 89 f250 with a 521 ci stroker. It has a 4 speed trans behind it. All I really know right now is it has a comp cam, hooker headers, big Holley double pumper carb and the stroker kit. About what horse power level am I looking at?
Old 11-15-2011, 12:51 PM
White Max's Avatar
White Max
White Max is offline
What compression ratio? Which Comp cam? What heads are on it? Has any work been done to them? What intake manifold is on it? What size is the carb? We need much more information if you want anything close to an accurate answer.
Old 11-15-2011, 01:54 PM
BRay09's Avatar
BRay09
BRay09 is offline
That's the problem. I'm not quite sure. I don't think the old owner knows either. Its a 750 double pumper. The heads are cast, that's a given. I believe it had an aluminum intake on it but not sure of a part number. I'll have to clean it up and look for it.
Is a 750 to small for a 460?
Old 11-15-2011, 01:56 PM
BRay09's Avatar
BRay09
BRay09 is offline
I'll have to do some testing to see what al it had. I'll try to post cam specs when I figure out out I'll talk to the old owner and see what he knows but he seemed pretty clueless, that's probably why I got the whole truck for 500
Old 11-15-2011, 01:58 PM
andym's Avatar
andym
andym is offline
The only way you're really going to know is to put it on a chassis dyno and run it.
Without specifics, anywhere from 500 to 900.
Old 11-15-2011, 02:22 PM
BRay09's Avatar
BRay09
BRay09 is offline
With 500 on the low end this motor should be just fine for me. That's a lot of power!
Old 11-15-2011, 02:24 PM
BRay09's Avatar
BRay09
BRay09 is offline
Like I said before though, I'll let you all know what I find out. Wonder what it'll get for gas mileage
Old 11-15-2011, 02:29 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Could even be less than 500. Especially with iron heads. Who build s a 521 with iron heads? What a waste
Old 11-15-2011, 02:38 PM
BRay09's Avatar
BRay09
BRay09 is offline
I have no clue brad. Like I said,I will let you know more about the specifics when I find them out.
Old 11-15-2011, 02:40 PM
Diesel_Brad
I would 1st find out if it is even a 521
Old 11-15-2011, 02:42 PM
White Max's Avatar
White Max
Agreed. I'll guess anywhere from 300-700 hp, but without details, we're all just shooting in the dark here.
Old 11-15-2011, 02:45 PM
BRay09's Avatar
BRay09
BRay09 is offline
[QUOTE=Diesel_Brad;11040612]I would 1st find out if it is even a 521[/QUOTE
To do that I'd have to tear it down to the bare block correct? Or is there a better way? I mean either way I bought a good parts truck. 500 bucks for a solid body and a 460 motor trans and t case. I can use the body for my other 89 pick up that's falling apart and the 460 trans and x case for my mud truck.
Old 11-15-2011, 04:17 PM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
Have you measured one of the header tube's for diameter...that would be a good indicator, of just how mean she was intended to be.
Old 11-15-2011, 05:11 PM
BRay09's Avatar
BRay09
BRay09 is offline
Looks to be a 1 5/8" primary to a 3" collector.
Old 11-15-2011, 06:01 PM
White Max's Avatar
White Max
A 1 5/8" primary is TINY for a 521 c.i. engine. Either way, like you said, you did alright for $500.
Quick Reply: 460 stroked to 521. how many horse?
