460 stroked to 521. how many horse?
Old 11-16-2011, 11:12 AM
BRay09's Avatar
BRay09
BRay09 is offline
Originally Posted by Blue Rebel
Fords also had the BW T-19, w/ no granny 1st. that was found behind the 6.9
Would they bolt to a 460? If not I wonder if it is actually a ZF
  #32
Old 11-16-2011, 11:18 AM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
Summit has many trannys to choose from
  #33
Old 11-16-2011, 11:27 AM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
yes, the older 4 speeds had removeable bellhousings. swap to the correct bellhousing, and it will bolt right up
**dunno about input shafts, dont think it needs to be changed, but im not positive
  #34
Old 11-16-2011, 11:29 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
The T-19 has a seperate bellhousing.
You can swap for a 460 pattern.
The 460 version T-19 had a low first gear, and the big truck version (think F-700) had an even lower first.
(nice for crawling)
There were three sets of ratios available for the T-19
  #35
BRay09's Avatar
BRay09
BRay09 is offline
I'll have to look into that. Thanks
  #36
Old 11-16-2011, 11:30 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Beat me to it.
Rep's when I'm not on my phone....
  #37
Old 11-16-2011, 11:31 AM
BRay09's Avatar
BRay09
BRay09 is offline
If only I had the money! A built up c6 would be great
  #38
Old 11-16-2011, 11:33 AM
BRay09's Avatar
BRay09
BRay09 is offline
Is the t19 a pretty strong trans?
  #39
Old 11-16-2011, 11:36 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Think of the abuse it gets in a school bus or under an F700
  #40
Old 11-16-2011, 11:46 AM
BRay09's Avatar
BRay09
BRay09 is offline
Very true. I think that's the trans my grandads F700 bucket truck then
  #41
Old 11-16-2011, 04:39 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do you mean to say that there might be a difference between diesel and 460 gasser input shafts?
No, I don't think so. (not in this era)
You might have to change the pilot bushing.
And of course you need a clutch with the correct splines.
  #42
Old 11-16-2011, 07:16 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Originally Posted by White Max
1 hp/c.i. isn't exactly stellar, either.
with a smooth idle and 91 octane its a pretty stout set of numbers.
i didnt say that it was the max the heads can produce, I just said I had just built a motor a little while ago that made almost 460hp with light portwork on the iron heads.
  #43
Old 11-16-2011, 08:42 PM
White Max's Avatar
White Max
White Max is offline
460hp/600tq are good numbers, they just aren't particularly crazy from 460 ci.
Smooth idle, 87 octane, 1 hp/ci:
http://i6.photobucket.com/albums/y20...g/P1100494.jpg
Smooth idle, 93 octane, and over 2 hp/ci.
http://i6.photobucket.com/albums/y20...e/P1110830.jpg
Last AND least...smooth idle, 87 octane, FAR less than 1 hp/ci.
http://i6.photobucket.com/albums/y20...1/complete.jpg
  #44
Old 11-16-2011, 09:20 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
I had a 4.6 that was a bolt on queen and made over the 1hp per cube (then had a 175 shot of nitrous)
I built an 03 cobra, made 550 to the wheels with just a ported blower and bolt ons (through stock cats and manifolds even) very impressive car.
And I'm driving around one of those pathetic efi 351 engines in my dd truck. (hopefully long tubes and stainless exhaust will free up some ponies and mpg but it really needs a cam swap)
  #45
Old 11-17-2011, 08:06 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
If looking for a trans, ditch the 4speeds(no OD) and go to a ZF5. Just as strong and you get OD
And as far as heads go. Almost any off the shelf aluminum head will flow better than a ported and polished set of SCJ heads
Quick Reply: 460 stroked to 521. how many horse?
