Project: Smogie...RacinNdrummins IDI build
#887
Just ordered my tubing for the new crossover, should be here friday, just in time for the weekend.
My driveshaft is all balanced out and ready to pick up, so Ill do that tomorrow.
Didnt make it to the welding shop to get more gas, I got caught up in other bs, but tomorrow I will will, and ill get some more pics of progress...
#888
Here is some pics of tonights progress...
Got my driveshafts painted and installed, and because the rear balanced out with less counterweight than a factory shaft, I felt I could put a sticker on it, being how I built it and all... This was my first retubing of a driveshaft ... I shortened the one in my bronco myself, but never have gone this far, lets see if I can fold the bitch up...
Also got my Walbro mounted, and filters back into the truck...
Anyway... more soon.
#889
#892
idk if i like it sucking fuel through the first filter...
i would have put an air bleed on the line coming out of the second filter. easy as a block with a #80 hole in it routed into the return line. (hole facing up of course)
how far are you from a video. just the up pipes?
#893
Whats the idea behind the air bleed? My system is a return style system, so it will purge any air as soon as the pump fires up.
No, I have lots of little stuff to tie up, and I still have to weld up my pipes. Still waiting on my bumpers and box to come back from powdercoat as well. I hope to get most everything tied up this weekend, its just a few little things holding me up. This week hasnt been very good for time, my wife went back to work, so Ive been watching my daughter for a couple days this week into the evening, and only had limited time to work on the truck.
#894
You know, I was at the auto parts store, and I had both style clamps in my hands, but I ended up with these because Ive never had any issues with them, and the FI clamps looked like they could be a pain in the *** in the future. I guess I could have gone that route, If they ever start leaking, I will.
#896
Thanks, and me either.
I dont normally throw out numbers, because even though I always have a number in my head, there is too many little things (like fuel supply, clutch, blah, blah, blah) that can interfere, but I feel confident enough with my pumps bench numbers, and with how much air this turbo has flown on other engines, that I think I will put down around 420rwhp and just over 800ft/lbs at the wheels, and maybe even more with water/meth, but it all depends on if everything holds up and and there is no little issue to jam up the works.
I am going to do an injector test dyno day as well, and the injectors that I will test out first here, and fire the truck on will be a set of stroked injectors, that will hopefully act like stockers at low fuel flow (idle, cruise, etc.) and flow big fuel at WOT, reducing the duration and load on the pump, even with a high pop pressure. The dyno will tell us what we have all been wondering about the injectors on these things.
#897
#898
didn't know that e pumps were that fragile.
if it were me i would put an air bleed down there so that the whole line stays full.
even with a bypass system i figure you could still get air to the ip (a lot less of course).
you mean to tell me you don't have her out there wrenching yet? lol
#899
I dont think youre understanding how his fuel system work, the second the key is on its circulating fuel. It would have all the air out of the system before the glow plugs kick off, assuming there was air there in the first place.
#900
Build looks great! How soon do you think the intercooler piping will be ready for sale and do you have a ball park on the price yet? The piping is the only thing holding me back from this project. I can bend tube but suck at cutting angles and this would be a real time saver. Thanks, I will even buy your proto type for the right price
