turn signals
Old Apr 12, 2003 | 05:43 PM
Seifferlein's Avatar
Seifferlein
turn signals
I have a 69 F100 and the turn signals stopped turning off after I move the wheel back to being straignt ahead. So I pulled off the wheel and I found some broken pieces of plastic ( and a dead bug?) but I don't see where it broke off from. I haven't done this on my truck before and am afraid of messing something up. What should I do next to see what is broken, what is most likely the problem. Thanks for the help.
brad
Old Apr 12, 2003 | 07:19 PM
Mil1ion's Avatar
Mil1ion
turn signals
You have a broken Cancelling Cam.
if we don't have one here at
www.motorhaven.com
You might be able to get one a parts place that stocks H.E.L.P. Blister-pak parts.
Oh ya, You can feed the bug to the birds or reptile.
It is no longer required in the Turn signalling system.
Old Apr 12, 2003 | 09:38 PM
maximumhorsepower's Avatar
maximumhorsepower
turn signals
One of mine broke off, so the signal only cancels when I turn left, and not right. A new switch is pricey, You might be able to find a good one in a junkyard, but most likely all that you'll find will be in the same shape as the one you have. I haven't been able to find one. Good luck
Old Apr 12, 2003 | 11:09 PM
buzzard's Avatar
buzzard
turn signals
The cancelling cams are available at most auto parts stores for around $10-$15.
Old Apr 13, 2003 | 08:30 AM
mustnggtkc2001's Avatar
mustnggtkc2001
turn signals
Can anyone tell me if the 1967 F-100 had the cancelling cams for the turn signals? If 67 did then mine needs replaced. Thanks
Old Apr 13, 2003 | 02:28 PM
maximumhorsepower
turn signals
I thought that the cams were an integral part of the switch, I guess I was wrong.
Old Apr 13, 2003 | 09:13 PM
Seifferlein
turn signals
I pulled the cam off today but it was not broken. However, I found a tiny cylindrical piece of metal with some wire attached. I finaly figured out that it was supposed to be attached to a spring like another piece I found behind the wheel. What do these things do? Would they be the result of my signals not turning off? I still don't know what the broken plastic pieces are from. They look like they were used to form ring but can't see where at. Any ideas? Also, does anyone know what the thread size of the stud on the wheel is, I stripped it and need to rethread it. I went to the hardware store but couldn't find a bolt that would fit the nut in order to identify the size.
maximumhorsepower- the cam can be seperated from the switch if you break the little round retaing clip.
thanks for all the help
brad
Old Apr 13, 2003 | 09:22 PM
Mil1ion's Avatar
Mil1ion
turn signals
You are right actually.
The problem with them has always been the Cam hook breaking off or the spring metal piece whch give the canceller its CLICK.
Some... you have to remove the rivet to repair > others are held in with a small screw.
You can purchase the plastic cam > snip the 2 wires > solder & wrap .... Voila ! A new switch
Old Apr 13, 2003 | 10:34 PM
inliner's Avatar
inliner
turn signals
That spring and cylindrical piece sounds like your horn brush. Did your horn work before? Mine shot out of the steering column when I pulled my wheel off, never did find it had to buy a new one.
Old Apr 14, 2003 | 10:28 PM
OldBlue67's Avatar
OldBlue67
turn signals
My '67 F250 has them. I would assume that the f-100 would too
Old Apr 15, 2003 | 10:53 PM
maximumhorsepower
turn signals
thanks Mil1ion I will have to fix mine, it gets real old having to cancel the signal myself.
maverick600
Feb 1, 2014 03:07 PM
paraskr
Feb 9, 2013 01:04 PM
beeser
Feb 3, 2011 10:38 AM
Metdawg44
Apr 9, 2008 05:52 PM
ksharon
Feb 4, 2005 08:33 PM
